Home > Technical (L322) > FBH |
CSK Member Since: 15 Oct 2010 Location: St Tropez Posts: 750 |
Stan - Thanks, yes I'll try at lower temperatures but as Rambles says the manual states that it should heat the interior below 15°C and vent at higher temperatures.
13th Dec 2013 10:01am |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 810 |
CSK
13th Dec 2013 3:41pm |
jak480 Member Since: 06 Dec 2013 Location: Degernes Posts: 44 |
Hi
13th Dec 2013 4:09pm |
Hi Rambles, Yes it has done the full cycle as the system stopped after about 30 min.. I started the car only at the end of the morning but haven't driven it today and had no low battery warning. Didn't want to try again this evening as I thought switching the FBH on twice in a day with no driving would run the risk of ending up with a flat battery. I'll try the system next time I use the car for a reasonable distance. |
13th Dec 2013 8:16pm |
was there any heat given out at any point in the 30 minutes?
14th Dec 2013 7:29am |
I don't know as I wasn't actually in the car. But when I checked the air blowing out was cold. I should think mine works on petrol. Couldn't hear any ticking noise either, from outside I could hear the unit (driver's side, on my LHD, somewhere near the side vent), like a blower but no ticking noise. |
14th Dec 2013 8:13am |
well if you dont want to know what happens so you can describe it to the dealer.....
14th Dec 2013 10:08am |
Hi Rambles, I'll check when I intend to use the car for some distance as it is not my only car and don't think trying the Timed Climate Control twice without using the car is a good idea as I will probably not be able to start the car after that. Thanks for your input, will definitely try and let you know. |
14th Dec 2013 11:31am |
Van Diesel Member Since: 27 Oct 2013 Location: Norfolk Posts: 183 |
Sorry to hi jack, but about to get my 08 TDV8 and asked the dealer (not MD) if there was a remote fob for the heater. He said no. Just wondered if it was lost by previous owner, how would I know if it was/wasn't fitted originally? Would like to get a replacement fob if it is fitted. |
14th Dec 2013 9:59pm |
CSK - you have a FFRR but no battery charger? |
15th Dec 2013 10:12am |
Hi Rambles, I do have a battery charger but wasn't aware this was a compulsory purchase when buying a Range Rover and never needed one before even though I'm on my fourth Range Rover! Maybe I was just lucky.
15th Dec 2013 2:38pm |
CSK
15th Dec 2013 2:50pm |
@ CSK |
15th Dec 2013 2:52pm |
Thanks Jak, will tell the dealer! |
15th Dec 2013 2:54pm |
