Home > Technical (L322) > FBH
Page 1 of 3 123>
CSK
France 2013 Range Rover Autobiography 5.0 SC V8 Causeway Grey
FBH
Got the car back from the stealer yesterday. They fitted a new FBH unit as the original unit was only blowing cold air. Tried it this morning (about 12°C this morning so it should have heated the cabin as I believe the heater switches on below 15°C) and the thing was still blowing cold air out after about 10/15 minutes. I'm really disappointed as they've had the car for quite a while and it is still not sorted. I'll try again, maybe it wasn't cold enough outside and the system ventilated only.
Post #228583 12th Dec 2013 3:34pm
Martin
Site Admin
FBH kicks in under 6 deg C?
Post #228584 12th Dec 2013 3:34pm
CSK
God Martin that was quick! The owner's manual says heat below 15°C but maybe it kicks in at a lower temperature.
Post #228585 12th Dec 2013 3:36pm
http://www.fullfatrr.com/wiki/FBH Thumbs Up ... - .- -.
Post #228586 12th Dec 2013 3:38pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
I thought it was 8 degrees. Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #228590 12th Dec 2013 3:44pm
CSK
Taken from the 2010 owner's manual on TOPIX:
- If the external temperature is 15°C (60°F) or lower, then the passenger compartment is heated using the auxiliary heating system.
- If the temperature is greater than 15°C (60°F), then the passenger compartment is ventilated by blowing in air from outside the vehicle.
My car is from July 2010 so technically MY2011, when looking at the 2011 owner's manual, the quote about the temperature has been deleted. As the dealer has put a new unit in I guess it will come with the new (altered) software.
Post #228600 12th Dec 2013 4:00pm
DMRR
Ah ... sorry I was rather stupidly assuming you meant as an aux heater (i.e. on automatically to help warm up the cabin - as in a TDV8). You've got an SC so it should in theory work along the lines you've quoted, however I think it's hit and miss as in the summer if I hit the remote on mine it heats the cabin even if it is (very rare I know) over 20 degrees C ..... your's seems to be switched the other way, as if it only had timed ventilation and no aux heater! (the BMW era 4.4' petrols have this option....) Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #228608 12th Dec 2013 4:13pm
CSK
Normally if you've got the option of "Timed Climate Control" which mine has, it shouldn't make any difference if it's petrol or diesel, it works in the same way (only those who have the option, not the standard item).
I've got the remote control, the timer function on the screen and so on. And the dealer just put in a brand new unit so for sure I have the apparently rare FBH option on a petrol car.
Post #228619 12th Dec 2013 4:27pm
i had the FBH option my former 4.2l SC Cool All my spelling errorz are belong to me!
2023 FFRR L460
2021 AM new Vantage
Post #228620 12th Dec 2013 4:32pm
CSK
Do you remember below which temperature the heater set in instead of the ventilation?
Post #228640 12th Dec 2013 4:57pm
fairwx
2015 Range Rover Vogue SE SDV6 Luxor
This may be relevant if the have replaced the FBH.
http://topix.landrover.jlrext.com/topix/co...tabs=false
Post #228650 12th Dec 2013 5:25pm
CSK
Thanks saw that but it doesn't give more info that what is already explained in the owner's manual.
I'll give it another try tomorrow early.
Post #228655 12th Dec 2013 5:36pm
honestly i never used it in 3.5 years of ownership Shocked Laughing i have put the remote control in the safe together with the spare key Smile All my spelling errorz are belong to me!
2023 FFRR L460
2021 AM new Vantage
Post #228671 12th Dec 2013 6:44pm
CSK
Tried it early morning at 9°C and still blowing only cold air, seems a new unit didn't solve the problem! Sad
Post #228795 13th Dec 2013 7:51am
i'd wait for colder temperatures as the wiki says less than 5 degrees for the fbh to work.. ... - .- -.
Post #228800 13th Dec 2013 7:54am
Page 1 of 3 123>
