Home > Technical (L322) > FBH |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1665 |
FBH kicks in under 6 deg C? |
12th Dec 2013 3:34pm |
CSK Member Since: 15 Oct 2010 Location: St Tropez Posts: 750 |
God Martin that was quick! The owner's manual says heat below 15°C but maybe it kicks in at a lower temperature. |
12th Dec 2013 3:36pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35368 |
http://www.fullfatrr.com/wiki/FBH ... - .- -.
12th Dec 2013 3:38pm |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
I thought it was 8 degrees. Land Rover Addict
12th Dec 2013 3:44pm |
Taken from the 2010 owner's manual on TOPIX:
12th Dec 2013 4:00pm |
Ah ... sorry I was rather stupidly assuming you meant as an aux heater (i.e. on automatically to help warm up the cabin - as in a TDV8). You've got an SC so it should in theory work along the lines you've quoted, however I think it's hit and miss as in the summer if I hit the remote on mine it heats the cabin even if it is (very rare I know) over 20 degrees C ..... your's seems to be switched the other way, as if it only had timed ventilation and no aux heater! (the BMW era 4.4' petrols have this option....) Land Rover Addict
12th Dec 2013 4:13pm |
Normally if you've got the option of "Timed Climate Control" which mine has, it shouldn't make any difference if it's petrol or diesel, it works in the same way (only those who have the option, not the standard item).
12th Dec 2013 4:27pm |
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4994 |
i had the FBH option my former 4.2l SC All my spelling errorz are belong to me!
12th Dec 2013 4:32pm |
Do you remember below which temperature the heater set in instead of the ventilation? |
12th Dec 2013 4:57pm |
fairwx Member Since: 10 Nov 2011 Location: bristol Posts: 124 |
This may be relevant if the have replaced the FBH.
12th Dec 2013 5:25pm |
Thanks saw that but it doesn't give more info that what is already explained in the owner's manual.
12th Dec 2013 5:36pm |
honestly i never used it in 3.5 years of ownership i have put the remote control in the safe together with the spare key All my spelling errorz are belong to me! 2023 FFRR L460 2021 AM new Vantage |
12th Dec 2013 6:44pm |
Tried it early morning at 9°C and still blowing only cold air, seems a new unit didn't solve the problem! |
13th Dec 2013 7:51am |
i'd wait for colder temperatures as the wiki says less than 5 degrees for the fbh to work.. ... - .- -.
13th Dec 2013 7:54am |
