![]() | Home > Technical (L322) > Sticky drivers door handle |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
For want of a better description, my drivers door handle is a little sticky. It seems to be catching slightly about half way through the travel when opening the door.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35656 ![]() ![]() |
you might temporally solve the problem with lubrication but i fear its the cable breaking down..i'd replace it asap before it breaks...there's one cable from the outside handle to the latch and another from the inside to the latch... ... - .- -.
My problem is with the outside handle, the internal handle is fine
^ and the fuse blows on the central locking. |
LOL look on the bright side!! |
wats39 Member Since: 08 Jul 2012 Location: fife Posts: 77 ![]() ![]() ![]() |
Same happened to mine. Kept putting it off then pop! |
