Home > Technical (L322) > Heated screen problem, how do I check it? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
May be easier to remove the top dash panel, then you can get at the wires to test ? .
29th Nov 2013 12:26am |
b20wht Member Since: 08 Apr 2013 Location: lincs Posts: 45 |
Ok I will give that ago thanks |
29th Nov 2013 10:40am |
Just had a look on youtube at the removal of the top dash panel and cant see the wires for the windscreen once its off! are you 100% sure that they can be got to by removing it? |
29th Nov 2013 7:18pm |
Someone must know how to get to these connections? I have searched all over and just cant find a guide or even a location (other than the bottom of the screen somewhere) Are they under the bonnet or under the dash? |
30th Nov 2013 7:44pm |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
I had an issue with a windscreen replacement where either, it was defective, or the connectors were damaged during installation. (Solution was a new windscreen.)
30th Nov 2013 8:31pm |
paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222 |
Pretty sure they are under the scuttle panel, take the plastic push-in clips out, ease it away from the glass either side and have a look....if correct, you will have to take the A pillar covers off etc to remove the scuttle. |
30th Nov 2013 11:40pm |
are you talking about the outer scuttle and A panels? or the inside ones? |
1st Dec 2013 12:49am |
Sorry, missed your reply, I mean the outer A pillar covers, they wrap over the plastic scuttle finisher, I seem to recall the connections are in front of the passenger, if you look in the wiki there is a copy of the WSM and this will give you a definitive description.... |
1st Dec 2013 9:36pm |
Thanks for the reply, I have had a look through the wsm and cant really find much on the heated screen at all. But I will get the scuttle off and have a look. |
1st Dec 2013 10:29pm |
