![]() | Home > Technical (L322) > NO ELECTRICS WHAT SO EVER DUE TO BAD JUMP STARTING |
oliver9627 Member Since: 25 Oct 2012 Location: Chipping Norton Posts: 51 ![]() ![]() ![]() |
Any help would be very helpful.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7970 ![]() ![]() ![]() |
Lets hope the reconnection works |
drivesafe Member Since: 19 Mar 2008 Location: Gold Coast Posts: 126 ![]() ![]() ![]() |
Hi Oliver and measure the voltage of your cranking battery and do this at the battery’s terminals.
My guess is you have blown the 5amp BCU fuse in the main fusebox (under the CD multiplayer)
Thank you for all of the replies. I now have some idea what to check for and do. I will let you know the outcome. Thanks Gone:
B3EEE Member Since: 23 Jul 2013 Location: S Wales Posts: 99 ![]() ![]() |
when this happened to my FFRR several years ago, it blew modules attached to the steering column. Downside was that they were not replaceable, came with a whole new steering column, and not cheap |
Thank you for all your help.
You lucky lucky b |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
Nice one. See our cars are not all bad.........
Had similar luck lately.
Sparkylee Member Since: 15 Apr 2012 Location: Guildford Posts: 85 ![]() ![]() |
Glad it's all sorted
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
Lucky |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
Done it a coulple of times, no problems so far......
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 ![]() ![]() ![]() |
The owners manual says it's fine to jump and be jumped started on the FF, I tried on mine when she had a flat battery but did not work as it was |
