Home > Technical (L322) > Knock Knock
Front differential. Many were recalled for checking and any problems should have been fixed - but worth paying attention. You might get a warning from a knocking sound on full lock at low speed.....
Post #225925 29th Nov 2013 10:41am
ksmith100
Scotland 2005 Range Rover Vogue 4.4 V8 Java Black
Hk
I read this and tried it but it wont do the knock unless on a rough road and even then only when turning right.
if it was the diff I would expect it to do it on either lock regardless of road surface but I could be wrong.
Also I know that the diff was modified in the recall. You are either at Le Mans or waiting for Le Mans
RSW MKIII V2 All Comms in Central Scotland
Post #225938 29th Nov 2013 11:11am
ksmith100
Fixed!!!
Been fixed!
Took it to the garage and we went for a long long drive. Went back with it and was under the car with them as they poked, prodded, pushed. Nothing looked worn. Left it with them and they stripped the entire suspension on the nearside.
The only thing they could find was a very very small amount of play in the ball joint of the upper track control arm, so little play that it didn't show when the car was sat on its wheels.
They changed the arm too as the bush was starting to degrade. Job done no more knock!
Thanks to all for their replies and suggestions. You are either at Le Mans or waiting for Le Mans
Post #226009 29th Nov 2013 7:27pm
Excellent news well done nothing better than finding the solution to an irritating problem!
Post #226011 29th Nov 2013 7:40pm
Glad you got it sorted, just fixed the annoying knock on mine. Basically decided that a scatter gun approach was best and swapped everything bar the upper arms, which i will do in the new year. There is nothing that can't be fixed with a hammer😜😜
Post #226020 29th Nov 2013 7:58pm
b20wht
that's good news, I will have a closer look at mine now.
Post #226027 29th Nov 2013 8:43pm
Mine was the inner bolt of the nearside lower arm was loose. Just needed tightening up and now silent as a mouse!
Post #226665 3rd Dec 2013 11:09am
