![]() | Home > Maintenance & Mods (L322) > Reverse from static sometimes not engaging |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
Its most likely the linkage, have a search around on here, there is plenty of info on it..
Petewake Member Since: 21 Oct 2013 Location: Coleraine Posts: 11 ![]() ![]() ![]() |
Thanks will take it in and see if they can sort that.
my friends car in auz does this and he has taken it to the dealers a few times with no luck, would be nice to let him know the out come.. V8 facelift Range Rover Autobiography 22" wheels.
Hey Guys,
I would hope so.
I know Martin, they said that as well mate, that it has sorted loads of them, I was just unlucky, nooooo. But hopefully that will be her all good. Cheers for the quick reply as well at the start. |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1259 ![]() ![]() ![]() |
I had a very similar thing with mine (2003). All forward gears were OK but reverse would hang for a while then go in with a bang, it got to the stage where you had to really rev the engine to get any drive. It turned out to be a crack in the valve block that was releasing pressure on the reverse ports (or whatever!) |
