Home > Technical (L322) > Possible Dumb Question 2010 LED DRL'S But Here Goes |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
They work when you turn on sidelights. Alternatively if you have iid tool I think some members have been able to enable that function. Present :2008 TDV8 HSE
21st Nov 2013 12:53pm |
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1098 |
The dealer will do this for you when they hang the fury dice on the rear view mirror. letters not necessarily in the right order |
21st Nov 2013 2:56pm |
GGX Member Since: 31 Jul 2013 Location: North Wales Posts: 61 |
Apparently they don't work as DRL. DRL would be main beam bulb on low voltage |
21st Nov 2013 10:25pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
L322's can NOT have the LED's initiated on the CCF files im afraid...The only way to have them on as DRL's is to wire them in that fashion... |
21st Nov 2013 10:35pm |
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 |
We've been here before Craig, it can be done My own 2010MY FFRR 3.6 TDV8 has just the front signature lights enabled as DRL's using my Faultmate MSV-2
22nd Nov 2013 10:18am |
Ahh, my point was it's not something a uk main dealer can do through the CCF files
22nd Nov 2013 11:40am |
carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717 |
Ajay, is a LR specialist likely to do this if LR won't?
22nd Nov 2013 7:59pm |
Worse case is an auto electrician wiring in a £4 5 pin relay! |
22nd Nov 2013 8:09pm |
Just need to find someone with fault mate now! |
26th Nov 2013 9:35pm |
That is brilliant since I do have a faultmate and I have my software license changed to the 5.0 MY 2010 5.0 SC Galway green and sand interior!!
20th Oct 2014 2:50pm |
tvrforever Member Since: 09 Feb 2016 Location: Bucks Posts: 55 |
sorry to resurrect - but is this something that a dealer or specialist could do on my MY2012 Westminster? |
30th Apr 2016 6:25am |
Yes, we can sir |
30th Apr 2016 9:17am |
Craig - great any idea of time & cost to do at all? |
30th Apr 2016 10:31am |
PM sent |
30th Apr 2016 10:20pm |
