![]() | Home > Technical (L322) > Another Windscreen Heating Question |
shalz Member Since: 28 Jan 2013 Location: where FFRRs roam free...! Posts: 507 ![]() ![]() ![]() |
Hi all,
NKSC Member Since: 09 Nov 2011 Location: Lincs Posts: 156 ![]() ![]() ![]() |
My new windscreen does this too. |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
Mine only clears on the passenger side. I'm told there are two fuses- one for each side. Anyone confirm this? |
Sparkylee Member Since: 15 Apr 2012 Location: Guildford Posts: 85 ![]() ![]() |
Not had to use the FFRR one yet but my 110DC defender has the middle line |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
Thanks all, huge sigh of relief for a change. This forum is tops! MY11 Vogue 4.4 TDV8 - "African Queen" |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
If you look very closely from the inside you can see the element nes in the screen... You will also see there is one or two missing in the middle hence your question... |
Thanks Craig. Took a look this morning and see what you mean. Should have looked more closely.
vogue man1 Member Since: 10 Nov 2013 Location: Eastnor hr8 Posts: 16 ![]() ![]() ![]() |
my screen dont work at all and cant seam to find out why unless the screen is damaged its the same one that came out for the factory in 2003...... Life to short for all the b### ###t
