Home > Camping, Caravanning and Holidays > Towing MPG
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Towing MPG
Towing MPG
When towing the caravan (twin axle Lunar Quasar FB) I found I was getting 20-21mpg (TD6)
However I have recently been towing a box trailer I find that when fully loaded I am lucky to get 18-19 and not much better when empty on the return journey. Admittedly I have the trailer loaded up but would say it weighs no more than the Caravan would have.
Trailer is one of those hire tow a box type with a tapered front 12' long.
Any idea's as the cross section of the trailer is a lot less than the caravan??
thanks Mine was a blue one! Smile
Post #224075 20th Nov 2013 11:13am
n1cktdv8
Andy,
The caravan structure lends itself to economy with a sloped from end. I found the same with my D3. With the caravan on I would get 22-24mpg and with a smaller, thought similar weighted box trailer it'd go below 20mpg - I put it down to the "box" in 'box trailer'
Haven't towed a box trailer with the FF but can say with my TDV8 I tow a Lunar Lexon 650 and I get very similar MPG as you do Thumbs Up Is this where I put the car details and a bit about myself ?........
Post #224078 20th Nov 2013 11:18am
Andy3681
Thanks
I thought it's to do with the profile or aerodynamics but it a surprising difference! Mine was a blue one! Smile
Post #224100 20th Nov 2013 1:19pm
Sounds about right.
Get high teens to low 20's towing my ultima tl. But its significantly heavier than your quasar, at 1900kg There is nothing that can't be fixed with a hammer😜😜
Post #224153 20th Nov 2013 8:16pm
Mark6r
Scotland 2018 Range Rover Vogue SDV8 Montalcino Red
Went to London in October and we where getting 16.9mpg according to the trip computer towing a sterling trekker at 1900kg had a lighter van before and never managed above 19mpg towing that.
Tried sitting at 50-55 but would rather spend the extra on fuel than take all day to get there. Gone
67 Nissan navara
67 C220 AMG
12 Tdv6 Discovery 4 HSE
09 TDV8 Westminster
59 BMW 520d touring
56 RRS tdv6 hse
02 td 6 hse
Post #224171 20th Nov 2013 9:41pm
Perversely i seem to get slightly better with the 1900kg tl than i did with the quasar 615 i had before Rolling Eyes There is nothing that can't be fixed with a hammer😜😜
Post #224174 20th Nov 2013 10:03pm
hammiegt
Ive got a bailey Pegasus 534 @ around 1500kg, dread to think what my mpg will be next year when I hook it up to my v8 petrol lol 2003 ffrr v8 vogue
Post #224176 20th Nov 2013 10:05pm
n1cktdv8
northernmonkeyjones wrote:
Sounds about right.
1900KG Shocked MIRO is only around 1460kg on that isn't it ?...what do you fill it with !! Is this where I put the car details and a bit about myself ?........
Post #224183 20th Nov 2013 10:36pm
24-25mpg unladen, 19-22mpg fully loaded at 3500kg. I drive fairly slowly with the trailer, esp when it's fully loaded.
I've not towed a caravan.
Post #224205 21st Nov 2013 12:03am
cleughy
England 2004 Range Rover Vogue Td6 Santorini Black
i get about 23mpg @ 60mph towing the van using the cruise control
Post #224232 21st Nov 2013 8:20am
Iv had it up plated from 1680 to 1900kg, as when we put two gas bottles, the mover, battery and a few bits of kit we were pretty much full!
Battery 30kg
Mover 70kg
Gas 30kg
Total 130kg
Original load 220k
Left us with 90kg for everything else.......
Which for a family of 4 isnt much at all. So a bit of grovelling to lunar followed and they let me have a chassis weight upgrade. Extra 220kg goes a long way and gives us 440kg of load to play with! Ore something like that, pretty early to remember exact figures tho Rolling Eyes
Tyres were upgraded to take the extra weight but thr rest of the chassis was rated at 950kg per axle! There is nothing that can't be fixed with a hammer😜😜
Post #224233 21st Nov 2013 8:37am
Andy3681
Seems to be (depending on model) about even on the mpg with a caravan and although Kurt's (WTF is on the trailer, aero engine?) is a big load it is just about shielded aerodynamically by the FF.
So the box trailer even though it has a taper at the front must be aerodynamically very poor.
Next trip a lower box trailer that sits below roof line I think.
Thanks for the replys.
PS. Because the Motorway height is disabled when towing the trailer had a slightly nose up attitude the Caravan club etc always say level or nose down, I think that's maybe for stability but I think it would also increase drag.
PPS NMJ ! FF@ 2.5 tonnes Van at 1.9+ Upwards of 4.5 tonnes! Whistle Hope you serviced your brakes Thumbs Up Mine was a blue one! Smile
Post #224313 21st Nov 2013 5:13pm
Thumbs Up Thumbs Up new front discs and pads and rear pads, and the ones on the van work too!
Pah 4.5 tonnes!!
Disco/ffrr with fully loaded 3.5 tonne indespension trailerbest part of 6.25 tonnes. Thumbs Up
Ps i believer that is Kurts new coffee table on the trailer! There is nothing that can't be fixed with a hammer😜😜
Post #224349 21st Nov 2013 7:46pm
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
Got 33mpg heading to London back in June with a car trailer on the back, 29mpg on the way back with a car loaded on the trailer. MPG's based on tank refills in London and when I got home. I also stuck to the speed limit...23 hours driving Yawn 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #224379 21st Nov 2013 9:44pm
n1cktdv8
Only had 4 trips out with caravan on back of FF so not had a fair chance on a longer run, though D3 remapped would peak at 26mpg on a decent motorway run...I remember a 26mpg on an N road through france with 1800kg Bessacarr 635GL, 2 canoes, 2 bikes and the odd drop of wine Whistle Is this where I put the car details and a bit about myself ?........
Post #224381 21st Nov 2013 9:49pm
