![]() | Home > Technical (L322) > Engine removal - 4.4l v8 BMW petrol |
IIRC there is a thread on Rangerovers.net where someone replaced the 4.4 with a scrapyard motor sourced from a BMW. As I remember it, there were no issues - pretty much straight in and out. Then again, I suffer from CRS, so I may be wrong.
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
i cant elaborate on what I know about the differences, only to say that a lot of people have asked the same question. maybe talk to a breaker with a bmw m62tu44 unit out of car, travel to it and photo it, as first point of reference. especially the block (underneath too.) (that's what I would do) secondly, if you raise front up and remove sump(s) and look under, if you loosen the cod rods, can you force pistons up? sounds like you have not run crank bearings, perhaps with a decent lit borescope, you can see scoring, and research whether you can rebore it. it might need a hone, and rings. you could be lucky. EARLY non tu mod engines, ie the early bmw m62 7series lumps had the alusil liners, they finished in about 98, THEN the tub44 vanos was introduced later on, have a good look through a 7 (E38?)series forum, as those guys blow their engines up too! -im interested how you get on. its a jewel of an engine. but it pays to replace a good few things whilst dissasembled. what was you milage? p.s inspect it first in situ, before you buy a lump, take it out and show to a machine shop, before you buy a lump. lastly engine ancillaries for this engine cost a lot secondhand so factor that into when buying an engine etc. just thinking, does the bmw engine, have the water cooled alternator for a start,. that comes off with the front timing cover, not a block issue. |
Mark_TDV8 Member Since: 18 Nov 2013 Location: West Sussex Posts: 6 ![]() ![]() ![]() |
Well, thanks to Chris (RugbyXV) we now have a genuine rangie 4.4 to build up and put in our l322...
yes keep us posted on the condition/observations of both engines! and the removal headaches!
any news on your engine project situation yet?
Hi johnboy,
hi again mark, -I was just looking on youtube, and found this which might interest you. with some bmw 7 vs. RR differences, and tips. this engine is an X5 lump, same as RR |
