Home > Technical (L322) > FBH AGAIN on my Td6 2004
steve9bug
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Right set the timer for this to come on as its was going to be frost overnight.
The light went orange and was on all night and still on when i got in the car today.
Car was iced up on front and back screens when i got in.
Don't seem to want to come on Crying or Very sad
The build sheet says its got remote heating but the guy i got the car off said there was a fob as he remembered but could not find it.
Do i need a new one to get the system working, or should it still work on the timer.
What do i check first please.
Post #223843 19th Nov 2013 9:43am
SteveMFr
Site Sponsor
It will def work off the timer. Does your FBH come on in its aux heat function? At under 5°C (? or 7° - always forget Rolling Eyes ) if you drive for about 4-5 mins and shut the car back off, you'll hear the FBH whining away and you should see some smoke/steam vapors under the front of the RR. Inside the vehicle you'll also be able to hear the ticking of the fuel pump from under the rear seat (not very loud). Or, with a cold car set the timer for a min or 2 later and wait. The start sequence takes about 1-2 mins: glow plug heats for 30-45 secs, then the fuel pum starts ticking for ~5secs, then you should hear the combustion air fan start whirring. The tone will change a few seconds later as the FBH ignites - sounds a bit like a small jet engine. If your FBH works, park heat should work as well.
If you have the receiver, you can buy a remote on ebay (ebay.de has better prices - use google translate and find a seller who accepts Paypal) and use that as well. I'd check to make sure you actually have the receiver first tho: open the right rear electrics compartment (boot) and look for the receiver module. You'll have a T80/90. It has a long black connector with 3 wires on one side and an antenna connector on the other.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #223863 19th Nov 2013 10:35am
steve9bug
Will look see if the box is in the back first i set the timer to start but never put a stop time in but no stop time will that matter.
Cannot say i have heard the pump or seen any smoke under wing but never looked for it.
Post #223909 19th Nov 2013 12:34pm
is the orange light supposed to be on all the time?...what does the manual say? ... - .- -.
Post #223913 19th Nov 2013 12:43pm
steve9bug
I have a black box with 2 black heavy wires coming out and a white thinner wire coming out.
Think its got a part No. on XUO 00010 but no T80 or T90 number to be seen
Post #223914 19th Nov 2013 12:46pm
SteveMFr
Site Sponsor
There are numerous black boxes back there... Laughing
The connectors will look like the ones in the pic - that's why I posted it.
No stop time, only start time.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #223929 19th Nov 2013 2:32pm
