Home > Technical (L322) > FBH AGAIN on my Td6 2004 |
It will def work off the timer. Does your FBH come on in its aux heat function? At under 5°C (? or 7° - always forget ) if you drive for about 4-5 mins and shut the car back off, you'll hear the FBH whining away and you should see some smoke/steam vapors under the front of the RR. Inside the vehicle you'll also be able to hear the ticking of the fuel pump from under the rear seat (not very loud). Or, with a cold car set the timer for a min or 2 later and wait. The start sequence takes about 1-2 mins: glow plug heats for 30-45 secs, then the fuel pum starts ticking for ~5secs, then you should hear the combustion air fan start whirring. The tone will change a few seconds later as the FBH ignites - sounds a bit like a small jet engine. If your FBH works, park heat should work as well.
19th Nov 2013 9:35am |
steve9bug Member Since: 25 Aug 2013 Location: sunderland Posts: 356 |
Will look see if the box is in the back first i set the timer to start but never put a stop time in but no stop time will that matter.
19th Nov 2013 11:34am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35379 |
is the orange light supposed to be on all the time?...what does the manual say? ... - .- -.
19th Nov 2013 11:43am |
I have a black box with 2 black heavy wires coming out and a white thinner wire coming out.
19th Nov 2013 11:46am |
There are numerous black boxes back there...
19th Nov 2013 1:32pm |
