Home > In Car Electronics (L322) > Parrot MKi9200 |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 |
Yes, I've got this fitted in mine and its pretty good. I've used Bury handsfree kits up to now, but my FF came with the Parrot fitted and I'm impressed. The sound quality is clear and conversations are easy. Only thing I would say is make sure you get the integrated speaker cable to mute the radio and play the conversation through the front speakers. Certainly when I play music from my iphone through the bluetooth you wouldn't tell the difference between that and the stero.
18th Nov 2013 11:15am |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 |
Another +1 for the Parrot here too - I've had the 9200 fitted in my last 4 FF's - superb piece of kit. Works a treat with Android phones and iPhones too.
18th Nov 2013 1:07pm |
paul271 Member Since: 19 Oct 2013 Location: Aberdeen Posts: 502 |
That seals the deal then!! Did you guys fit yours yourselves? |
18th Nov 2013 1:52pm |
I didn't - I got the same chappy in each time though. Does a cracking job. If you are near Hinckley (in Leics) I can send you his details. |
18th Nov 2013 1:54pm |
Thanks for the offer mate but I'm up in Scotland! |
18th Nov 2013 4:32pm |
Mine was in the car when I bought it. I've installed Bury systems myself and if you are reasonably good with removing trim and car electrics it will be relatively easily as the principle is just the same. You basically need to take power from the head unit and send mute signal/audio output back to the headunit. The display, mike and additional power leads are just plug and play.
18th Nov 2013 5:54pm |
Cheers Nick. If it's all just plug and play then it sounds pretty straight forward.
18th Nov 2013 6:32pm |
Mph28mph Member Since: 16 Jun 2013 Location: Wigan Posts: 112 |
I have a 2002 vogue also but I didn't think it was possible to intergrate a parrot into a vogue due to the complex wiring, amp in the boot etc.
18th Nov 2013 10:21pm |
Yeah no problem mate. |
18th Nov 2013 10:44pm |
Definitely possible as I have it installed in mine with the output through the speakers. Having looked into it a bit more, I think you'll need a 5m ISO extension cable to run from the parrot unit to the amp in the boot. Give Parrot a ring tomorrow and they'll tell you what you need. Current Fleet:- 2018 Discovery 5 3.0 HSE 2021 Ford Ranger Wildtrack 2019 Ford Mustang Bullitt 5.0 V8 1993 Defender 90 200TDI Pickup Gone - not forgotten 2016 L405 4.4 SDV8 Vogue SE 2012 L322 4.4 Westminster 2004 L322 4.4 V8 Autobiography LE 2000 P38 RR 4.0 HSE (ex Clarkson test car) |
18th Nov 2013 11:26pm |
cheers nick. |
18th Nov 2013 11:32pm |
That's right you do need the 5M extension to the boot - as mentioned fitting isn't terribly hard - but to make it look OE you do need to remove a fair amount of trim to hide the wiring.
19th Nov 2013 10:21am |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 790 |
2003 vogue with sat nag and with the kit fitted by pro fitter. It's crap. iPod only syncs half the time and the little screen is impossible to see and read in daylight. The remote control module is small and fiddly, eats batteries and works when it feels like it. |
19th Nov 2013 7:56pm |
I have an iPhone 4S which connects every time automatically. Have you put the latest updates on it - there was a new update from Parrot back in May which resolved a lot of Apple connectivity issues.
19th Nov 2013 9:33pm |
