Home > Technical (L322) > Possible Transmission Fault - Help Please
stevegt
United Kingdom 2006 Range Rover Autobiography 4.4 V8 Cairns Blue
Firstly, hello all sorry I've been away for quite a while.
I need some advice from the technically minded amongst you before I part with my hard earned cash at the Stealers.
A couple of months back I had "TRANSMISSION FAULT" pop up on the dash. It happened only twice and hasn't reappeared since.
Separately and may be a few weeks later I had a strange issue show up at slow speed (around 20 mph) and turning into a side road. It was a grinding noise (similar to the noise when HDC is working) and the DSC light flashing. This was coupled with a loss of power and it only lasted a couple of seconds at most.
The DSC issue has happened 3 times now and I think I show get it fixed now, especially with winter starting to take hold.
I initially thought a faulty ABS sensor but I think it maybe a little more complicated than that. Do any of you have any ideas or seen this before? Nothing popped up in the search but this can't be completely unique.
Thanks in advance.
Steve 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior
Post #223300 15th Nov 2013 11:47pm
paneldamage
Regarding the later issues, they sound a lot like the symptoms I had when my airbag was getting ready to pop... Look thru my old posts? Under 'signs of imminent air spring failure'....
Post #223302 15th Nov 2013 11:52pm
hoppy
England 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
i would find a local garage with a diagnostics first..
(were in worcs are you)
your welcome to have a trip to mine (gods country) to hook up
to my rsw
then take it from there free use of "RSW" all comms to anyone nearby
Post #223312 16th Nov 2013 7:30am
How far from us are you? GL11
You are welcome to book it in and we'll see what we can find for you sir Bow down
Post #223320 16th Nov 2013 9:20am
if you've been away for a while Steve , possibly the range hasnt been driven much so i would check the battery condition first..
...and Craig is only down the road from you and he will look after you.. ... - .- -.
Post #223333 16th Nov 2013 10:13am
stevegt
Thanks for all of the replies - Stan I was saying I had been away from the forum for a while... The car has been driven regularly!
Okay I have just discovered something else that may or may not be related. Yesterday, after fitting the winter wheels, I thought I would pop down the road and on the way back came down the drive in low range and HDC on. On selecting forward gear a short grinding noise is heard from he front when pulling away and the brake peddle vibrates, like HDC is activating. It only lasts a second at most and the same is true for reverse gear also. It only happens on the first pull away following the gear change, subsequent stop/starts did not produce the symptoms and before it is mentioned, yes I have had the front diff recall completed.
As suggested above about the air spring I have had the car all the way up to extended mode and left it for a few hours. The car remained at height and the compressor remained shutdown for the duration.
Now my understanding is that the DSC and HDC are both controlled through the instrument cluster for on/off commands and the actual operation is then dealt with by the ABS module. Does anybody has access to the traction contol system section in the WSM? My copy just directs me to the supercharged model manual which is useful (not).
Cheers
Post #223498 17th Nov 2013 1:31pm
there's a 2006-2009 workshop manual download here Steve,
http://www.fullfatrr.com/forum/topic17623.html
my thoughts would be the abs sensor tbh especially as when you fitted your winter wheels the juddering appeared ,maybe you knocked/moved the sensor?.. ... - .- -.
Post #223500 17th Nov 2013 1:39pm
stevegt
Okay just thought I would update you on this one.
Had the car in at Listers in Droitwich and there were no fault codes stored. I wasn't able to replicate the issue but did my best to describe it in a lot of detail. After checking the visually checking the suspension (airbags and airlines) the technician discovered the ride height sensors on both front wheels to be loose with corroded connections. These have been cleaned up and fixed back in place. Hopefully this will have fixed it! 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior
Post #226662 3rd Dec 2013 10:36am
