Home > Technical (L322) > Moving it |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
Will it be stood inside or outside?
15th Nov 2013 9:40am |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
There is something in the back of my mind about the age of cars allowed in singapore.. Previously..
15th Nov 2013 9:45am |
It will be outside in Holland unless there is enough space inside the storage building. They can run the engine but not drive it. Due to Dutch tax rules it it can't be driven by a Dutch resident. I can drive it in Holland because I am no resident anymore though still have a Dutch passport. Has to do with taxes taxes mainly.
15th Nov 2013 9:47am |
That's why it's going to Malaysia. |
I'm not importing it into Singapore. I can't due to it being LHD and way too expensive anyway. I can import it into Malaysia on the MM2H visa and that is taxfree import. Also that way I can drive on cheap Malaysian petrol. MY 2010 5.0 SC Galway green and sand interior!!
15th Nov 2013 9:49am |
I'm thinking of stopping there for weekends either side of a couple of weeks in Southern Thailand. Never been there before. Here's a noddy guide to long term car storage. |
15th Nov 2013 9:50am |
Thanks for the wikihow!
15th Nov 2013 9:56am |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
When I shipped mine I used my IID tool to lock it in build mode and that stopped the suspension from dropping and letting the whole thing bash about in the container . 2008 MY Supercharged
15th Nov 2013 11:08am |
Thanks Axle, good tip. I can use the Faultmate and do that as well (It's called transport mode in the faultmate i believe and also limits the max speed). MY 2010 5.0 SC Galway green and sand interior!!
15th Nov 2013 11:59am |
Sure, I'll let you know, and thanks for the tip - I don't know the area. |
15th Nov 2013 2:03pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
dont forget the lube Present :2008 TDV8 HSE
15th Nov 2013 2:06pm |
If its easy enough to do one thing would be to take the plugs out and drop a tiny amount of engine oil down each cylinder, just a few drops, and quickly spin the engine for as quick as you can click the key with the plugs out to get the oil all around the bores. Could be hard to do on an SC mind.
16th Nov 2013 12:52am |
