Home > Technical (L322) > rear diff
ARH Vehicle Logistics
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
rear diff
hi all does anyone have a pic of the rear diff on a 322 showing the filler hole??? guna change oil in diff tomorrow and would just like to make sure.
thanks guys
Russ If i could would you!!!!
Post #223418 16th Nov 2013 9:44pm
any good?
Post #223419 16th Nov 2013 9:50pm
Before you fill it up make sure you have the correct fluid, the active diffs have a different fluid than the open standard diffs. May apply to you, may not. There is nothing that can't be fixed with a hammer😜😜
Post #223421 16th Nov 2013 9:58pm
thanks but cant see the filler hole
Post #223422 16th Nov 2013 10:01pm
top arrow is the filler on mine. There is nothing that can't be fixed with a hammer😜😜
Post #223424 16th Nov 2013 10:09pm
It's very obvious when you are under it my friend Thumbs Up
Post #223434 16th Nov 2013 11:57pm
Thank you all for your help, I will get under it tomorrow and have a look!! will wait for local stealers to open and get the fluid from them.
Cheers Russ If i could would you!!!!
Post #223436 17th Nov 2013 12:10am
£20-£25 for the fluid from dealer Thumbs Up
Post #223437 17th Nov 2013 12:16am
get in!! cheap at twice the price....
Post #223438 17th Nov 2013 12:18am
