![]() | Home > Technical (L322) > air supensioninactive prob only have jeep2weeks |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16336 ![]() ![]() ![]() |
Craig you have a pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
This is a wind up now, surely? Previously..
Pauline the transvestite racist strikes again? |
Guys, the OP's first language is not English, I doubt his second language is English either, maybe take that into consideration |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 325 ![]() ![]() ![]() |
I believe, even ITALIAN is not his language, look at my fantastic italian conclusion.... L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
hse 2004 Member Since: 03 Nov 2013 Location: banbridge Posts: 27 ![]() ![]() ![]() |
Problem sorted after a look at the multi plugs on ride height sensors .I disconnected battery and jacked her up leaving boot open compresser plunged out fuses relay with mulitplugs disconnected I sprayed inner and outer case and components with electrical cleaner from hard ware store and damp out from around a pound greasey 2 harden forumual taped up wit plumbers tape and connected.wheels back on .did a by pass on relay with electrical wiring pins five 2 three.let compressor run for five or so minutes.oh b for compressor reconnected battery leaving dash a disco of lights.as per on any battery disconnection wheel left two right and center.took her for a rip and hey all lights reset on Manuel button and up down working with no probs,the conclusion that I have came two is aloose damp or dirty connection on ride height sensors .but hey these multi plugs can b tricky two disconnect and connect .hopefully this will b the result I was hope hand of road in field bumpen around road rip and still going all good.this prove diagnostic computer can fix on temp and that a code can b broken if u look deep enough.oh Stan battery was hitting 14.sum thing nr test 9.but good point.I hope this can help any1 with same prob as I'm sure any local RR dealer cashen in on muilty plug faults. |
Glad you got it sorted. |
The number of times I have stayed through voice speck is shocking.new hobby is the wee replica Mr 2 spider .if any likes two c the hobby and take it on it 93 model due 2 my confusion of voice keys xctra.I c hopefully but picuters up of is done its around a six number two months project.this spider has in general cobra bucket seating Rosso red withe a with detail trim auto recondition box all spider kit is on t bar exchanced 4 electrical panoramo ic roof.all is needed is a v8 engine and of course a straight through titiiem ppli'.pipe.....any offers? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35634 ![]() ![]() |
result.. |
Cheers bibg is now I mean Big man |
I have to admire you perseverance. Good to hear you got it sorted. |
A what jeep jeep jeep as in a for wheeled drive.ha ha OK RR exclusive or just big noised. |
