Home > General > Steep icy descent: HDC or 1st low gear? |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1199 |
Personally, I'd go with HDC every time in the situation you describe.
12th Nov 2013 3:04pm |
Simple1 Member Since: 01 Jun 2013 Location: Somerset Posts: 112 |
Only tried this once and in a Sport. The decent was totally out of control with wheels locking up. The same car won't come up a minor slope even in snow/mud settings. Put it down to the wide "road" tyres but put me off ever trying it again. 2.7 tonnes heading down a snow covered hill totally out of control was an adventure too far and required underwear change after meeting a Fiesta coming up the hill. TDV8 Vogue SE 2009.
12th Nov 2013 4:08pm |
CSK Member Since: 15 Oct 2010 Location: St Tropez Posts: 750 |
Thanks for your thoughts. My idea is that you should keep the wheels spinning and avoid braking. When I used HDC in high gear, it worked constantly on the brakes whereas low gear in 1st was fine but very slow, at least it got me down the hill. The problem was mostly inappropriate tyres for the conditions.
12th Nov 2013 4:36pm |
stuempf Member Since: 02 May 2013 Location: Frankfurt am Main Posts: 19 |
If the tires have no grip there is no chance to overcome physics.
12th Nov 2013 4:41pm |
Danke Sehr! Very informative. Do you know if HDC can be used in low gear? |
12th Nov 2013 4:46pm |
Moral of story is decent tyres. My workhorse L200 has open tread off road tyres and has gone everywhere it was asked in four wheel drive. It did once slide backwards down a steep Icey slope even though wheels were stil going forwards. Use of a snow bank stopped the problem but in fairness, you couldn't even stand on the road. TDV8 Vogue SE 2009.
12th Nov 2013 4:52pm |
HDC that what its for! |
12th Nov 2013 4:56pm |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
Not had the opportunity to test out the HDC on ice in my FF, but a couple of years ago, I used HDC on a discovery TD5going down a steep icy slope and it was amazing. Felt perfectly safe and in control. I did have ATR tyres on as well 56 TDV8 Vogue SE
12th Nov 2013 6:16pm |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
HDC will maintain the speed you set up to a certain maximum. If I was going down a very steep hill, I think I'd have everything on to get the most out of it. So, HTC, LOW in 1st gear, and TR in snow mode. I would also stop, dead, at the top of the hill, then start heading down without using the accelerator. The car should then be primed to descend as slowly as possible. There are limits, of course.
13th Nov 2013 2:24am |
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 |
Tried both ways and as said you cant get over the laws of physics It has scared the C**p out of me a couple of times here in Buxton.
13th Nov 2013 8:47am |
simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650 |
In the past I used low range in 1st or 2nd, HDC on and then use the cruise control buttons to reduce the HDC target speed. Terrain response in the snow setting to dull the accelerator and just let the vehicle creep down the slope without any feet on the pedals. Did this on a really steep slope which was covered in sheet ice and had no issues even with a summer biased tyre on. As mentioned in a previous post, stop at the top of the descent and then proceed in a controlled manner. Winter tyres will make a big difference to overall levels of grip, but the systems in the car should make it manageable with all season tyres as well. |
13th Nov 2013 9:18am |
Thank you all for your very informative replies. Great to have a feedback of your own experiences!
13th Nov 2013 10:02am |
@ CSK
13th Nov 2013 10:03am |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
That's because aggressive tyres put less rubber down onto the road - it's a trade off, they are good in virgin snow, but not ideal on ice. Land Rover Addict XXXXXXXXXXXXXXXXXXXXXXX Previous XXXXXXXXXXXXXXXX 2009 5.0V8SC Autobiography 2006 4.2V8SC Autobiography 2004 4.4V8 Vogue |
13th Nov 2013 11:02am |
