Home > Technical (L322) > air supensioninactive prob only have jeep2weeks |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1665 |
What did the fault codes say or did you just clear them without reading? |
12th Nov 2013 10:16pm |
hse 2004 Member Since: 03 Nov 2013 Location: banbridge Posts: 27 |
Code reader Says no fault soul this b down 2 a loose senor connection if so o u no were |
12th Nov 2013 10:59pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35108 |
whats the condition of and how old is the battery? if around 3/4 years old i would put a new one on.. ... - .- -.
13th Nov 2013 9:15am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16230 |
If the lights are out there will be a code... Take it to someone that knows what they are doing before your sat on the side of the road on your bumpstops scratching your head... |
13th Nov 2013 9:28am |
^^ agreed. And threads merged again... |
13th Nov 2013 9:30am |
Prepare for a new thread
13th Nov 2013 9:40am |
hse2004 obviously has a problem with spelling and is in a bit of a fix so it would be appropriate as conscientious forum members to try and help him.. ... - .- -.
13th Nov 2013 9:43am |
Hear hear... I would guess maybe even English is not his first language... |
13th Nov 2013 9:48am |
But i bet his English is better than most of your F, D, SP, NL etc etc etc (im sure you all get the point) |
13th Nov 2013 9:50am |
If I disconnect the battery and touch positive lead 2 negative .could this work or cause a prob |
13th Nov 2013 10:27pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
It's ok... It will not cause a problem.... As long as the battery is definitely disconnected... Previously..
13th Nov 2013 10:32pm |
Will try 2maro and c if it clears it.will report back.thanx |
13th Nov 2013 10:40pm |
It won't clear the fault |
13th Nov 2013 11:45pm |
Any tips |
13th Nov 2013 11:51pm |
