Home > General (L405) > Timed Climate - Enable .. able?
fairwx
2015 Range Rover Vogue SE SDV6 Luxor
As some will know, timed climate (+remote) is a £1000+ option on the current L405.
I know that the Timed Climate can be enabled on the CCF if you have the SDV8 (as a fuel burning heater is equipped). This can be tested/confirmed by using the 'rest heat' function on shutdown of engine (according to manual only available if auxiliary heater is fitted).
Disco 4 owners can activate TC and order the remote + receiver for about £50.00. Although it is the old MOST system but same new software group.
Anyone brave enough to try on the L405?
Post #222472 12th Nov 2013 8:32pm
cripboy
Scotland 2015 Range Rover Vogue SE SDV8 Corris Grey
Hi
has anyone been able to answer this? just about to collect a MY15 Vogue SE (Ex Demo Car)
Keith Regards
Keith
Post #327222 11th May 2015 5:43pm
Autobiography
2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
I don't think it's that simple on the L405 I'm afraid. Land Rover aren't going to make things that easy.
I didn't think it was an option on the L405? Certainly was standard on mine and I've used it. Much better than the L322 version.
Post #327264 11th May 2015 9:20pm
Re: Timed Climate - Enable .. able?
Don't tell me that after I sold my IID tool as I though there were no L405 functions I wanted Big Cry
Post #327267 11th May 2015 9:24pm
Mikey
The tool is being developed all the time. Full 405 coverage will be available soon
Sorry
Post #327313 12th May 2015 5:23am
cripboy
Mikey
Are you saying this can be done?
Keith Regards
Keith
Post #327317 12th May 2015 6:27am
Mikey
If there is an option in the CCF to enable it, and all the required hardware is present and correct, then no reason why it can't be enabled
And if the option is not yet available in the CCF, I am sure it won't take GAP long to add it in Thumbs Up
Post #327402 12th May 2015 11:28am
