Home > Technical (L322) > iidtool prob
Tallsaj
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
iidtool prob
Hi guys I got a problem with my iid tool I used it last about 1 week ago it was going okay. I hooked it up today it shows on the car but I cant use the controls on the steering functions any ideas Question Question Question
Post #222272 11th Nov 2013 9:39pm
This sounds like one to get in touch with GAP about..... .
Post #222301 11th Nov 2013 11:08pm
Is your handbrake on? Is the ignition on 11?
Post #222304 11th Nov 2013 11:14pm
make sure the engine is running, that will ensure the full voltage is getting round the ecu's..
also check the pins on the obd and the iidtool to make sure they are not bent.. ... - .- -.
Post #222325 12th Nov 2013 8:08am
SteveMFr
Site Sponsor
Your ignition goes to 11? Shocked This I need!
Laughing
JK - thanks for the help, Craig.
Tallsaj,
check the LED on the side of the IIDTool. You should see a series of rapid blinks as it boots up and then, if you press one of the cruise buttons, you should see a solid light as long as you hold the button. This not happening properly is not uncommon. The cause is usually loose pins on the female OBD connector in your RR.
If you don't see the LED light when you press, send us a mail to Support @ our website and Patrick will get some pin repair pics over to you.
Steve
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #222369 12th Nov 2013 10:37am
