Home > Technical (L322) > 2003 Vogue Drivers door wont lock/unlock with key?
Plant
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Only had my Rangey for about 6 weeks and on friday the key remote was playing up and I couldn't lock my car with the remote.
I tried to lock the car manually with the key and it wouldn't lock! The key turns no problem but it just doesn't do anything. The drivers door handle has always been very stiff compared to the other handles on the car so I am guessing it needs some adjustment. Is it likely that the door cable just needs replacing or re-seating to get the key to work the door lock?
Don't want to get caught short with a flat battery or dead battery in the remote in the future Crying or Very sad
Post #221924 9th Nov 2013 10:51pm
Use search, I repaired mine a year or two ago
Post #221930 9th Nov 2013 11:31pm
Plant
Tried the search but keywords are quite specific Rolling Eyes . Any chance of pointing me in the right direction?! Thumbs Up
Post #221931 9th Nov 2013 11:40pm
Odd that coz when I searched a few threads came up that I replied to Shocked
Here are the details since your search facility doesn't work
DO NOT TAKE THE DOOR CARD OFF, do not touch the door card, there is no need to remove it, only remove the outer handle and lock and reset the cam to the central position.
Open the door and look at the back, there is a grommet, remove this and it gives access to a torx bolt, remove the Torx bolt and the handle comes off. The lock assembly then lifts out and you have to realign the part that's left inside the door. Just use a screwdriver to do this and reassemble.
When you look inside you will see a slot similar to the either image 1. 2. or 3.
below, the slot could be in various positions depending on how it popped
Using a straight blade screwdriver gently reposition the slot until it is like the image below
Carefully refit the handle, Torx bolt and grommet and test to ensure it is working
Post #221934 10th Nov 2013 12:29am
Might be an idea to put this into Wiki
Post #221935 10th Nov 2013 12:32am
Plant
Thank you, that was much more helpful Thumbs Up Thumbs Up Wink
The problem is that I'm confused now as the info I retrieved from the search function suggests that I need to take the door card off?
http://www.fullfatrr.com/forum/topic15689....ivers+door
Was hoping to tackle this today but not too sure what to do now as I am not very mechanically minded!
Thanks again.
Post #221940 10th Nov 2013 7:29am
Well if you're not very mechanically minded why not leave it to the professionals
Thud
Post #221944 10th Nov 2013 8:21am
Plant
Because I believe in trying to do things myself, I just need to be armed with methodical instructions!. Wink
' open the door and look at the back, there is a grommet, remove this and it gives access to a torx bolt, remove that and the handle comes off. The lock assembly then lifts out and you have to realign the part that's left inside the door. Just use a screwdriver to do this and reassemble.'
Is this fix just for the key issue? I am assuming I will need to change the external pupil cable for a smoother handle open/close action?
Thanks
Post #221948 10th Nov 2013 8:47am
Plant, all for you doing jobs yourself my friend... But sometimes there are jobs to leave to the professionals... I personally think this is one of them... It's quite tricky & if it goes wrong! You could be seriously in the mire... Thumbs Up
Post #221949 10th Nov 2013 9:02am
Plant
Thanks Craig, but I've fixed the key locking issue now Laughing
It was actually really simple thanks to the clear instructions from 47p2.
The drivers handle is next. I think the cable or handle may just need re-adjusting so may take the card off today.
Post #221954 10th Nov 2013 9:27am
Plant
Ive had the panel off and the cable seems to be in tact and in place. The handle is rather stiff though, I have to put my thumb on the lock to get enough force/leverage to pull the handle open. I think it may be prudent to order a spare cable in case of emergency!!
Post #221973 10th Nov 2013 11:16am
Try opening the door, clicking the latch across with the door open (using a screwdriver) then pull the handle and see if it releases easily... If it does, close the door slowly and see if the striker on the pillar is pushing the door up or down or too far in? Can also make the door hard to open... (kind of initial jolt as the latch releases) if so, then it needs the torx bolts loosening and the striker plate aligning Thumbs Up not too loose though or there will be lots of wind noise Thumbs Up
Post #222005 10th Nov 2013 2:11pm
Plant
Cheers Craig, will give that a try next weekend Thumbs Up
Post #222030 10th Nov 2013 4:15pm
Plant
Unnecessary quote removed
Just tried that now but it seems to line up ok with the striker plate. Handle is still stiff even after closing the latch with a screwdriver.
I think I may just give the dealer a call tomorrow and get him to sort it. Rolling Eyes
Post #222032 10th Nov 2013 4:25pm
Worth a try Thumbs Up
Post #222038 10th Nov 2013 4:59pm
