Home > Wheels & Tyres > Swollen Nuts - Warranty Item ?
jez000
United Kingdom 2011 Range Rover Vogue SE TDV8 Bournville
Just put on my winter tyres (probably a bit early) and about 75% of the nuts are swollen, I managed to get them on and off but they will become a problem soon, I know this is a known problem but has anyone had them replaced under warranty ? (mine is just coming up to 3 years old) 2021 P400 Silicon Silver AB
Gone 2011 Bournville TDV8 VSE
Gone 2008 Black Canadian HSE LUX
Post #221892 9th Nov 2013 6:52pm
Vogue
Yes, several years ago on an 06 MY
Post #221893 9th Nov 2013 6:58pm
pld118
Swollen nuts... How so?
Post #221900 9th Nov 2013 7:31pm
^ The nuts corrode under the stainless skin and expand the stainless so as to prevent the wheel brace from fitting over the swollen nut.
I had to carry an imperial sized socket to fit over my swollen nuts as the OEM wheel brace would not fit on all of them.
I ended up buying a complete set from Dan.
It's a very common problem I believe. Best get your socket set out and get a socket that fits. Keep it in the car... Just in case ! Previously..
Post #221901 9th Nov 2013 7:44pm
Vogue
Rust, they didn't last 2 years on a new RR
Post #221902 9th Nov 2013 7:45pm
pld118
Thank you both and good tip too Contraband Thumbs Up
Ps... Are we saying they swell in poor weather or just when they reach a certain time of life (had all 4 wheels off a few weeks ago in better weather and no issues at all, aside to spraying some WD40 on a few nuts that were very tight)?
Post #221903 9th Nov 2013 8:12pm
paul271
Scotland 2002 Range Rover Vogue Td6 Epsom Green
My nuts are also swollen!
Post #221905 9th Nov 2013 8:31pm
Anything you can do youself to release the pressure or do you need to go to a professional?
Post #221941 10th Nov 2013 7:53am
jez000
Thanks chaps I'll get them swapped before the vehicle goes out of warranty. 2021 P400 Silicon Silver AB
Post #221967 10th Nov 2013 10:48am
Someone had to:
mod edit, pic deleted.. .
Post #221971 10th Nov 2013 10:56am
Wonder if that will get deleted Whistle ====================================
Post #221980 10th Nov 2013 12:14pm
Laughing .
Post #222006 10th Nov 2013 2:12pm
I see... Took your time Laughing
Post #222008 10th Nov 2013 2:19pm
tboner001
England 2014 Range Rover Autobiography SDV8 Fuji White
How about a 7 day course of antibiotics that may sort your nuts ! Twisted Evil Far to many gone...
Post #222019 10th Nov 2013 2:52pm
jez000
Update on this thread, all were replaced under warranty along with the locking nuts that were showing signs of corrosion. Thumbs Up 2021 P400 Silicon Silver AB
Post #244781 25th Feb 2014 11:22am
