Home > In Car Electronics (L322) > Hybrid Tuner
paul271
Scotland 2002 Range Rover Vogue Td6 Epsom Green
That looks like the un identified Censored that I put a post up about that's rattling about in my boot!!!
Post #221891 9th Nov 2013 6:37pm
Discotigger
Keep a look-out on fleabay for any hybrid tv tuner with the following serial numbers:
AH42-19C063-AE
AH42-19C063-AF
AH42-19C063-AH
I got one with the AH suffix...off a 2010 RRS and it works perfectly on my MY05FFRR
Of course, we now have the hassle with the 4G signal crap-up, so I have to get the software updated...but that's covered in another thread!!
Post #222072 10th Nov 2013 8:25pm
Andy
Is that plug and play then?
Post #222120 11th Nov 2013 8:51am
Discotigger
Yep,
they just plug straight in and don't need any additional wires, etc. Apparently, if you've got a good diagnostics tool, you can also set up the channels, etc. on it...at the moment, each time I go onto the TV option through the sat-nav I have to set up the channels through the 'Auto' button.
I got mine off fleabay for £260-00, so just keep a lookout for the correct numbered TV units.
Post #222153 11th Nov 2013 12:05pm
zetjester
United Kingdom 2002 Range Rover Vogue Td6 Alveston Red
I have just bought gvw's unit (cheers again Gary)
Removed leads from original unit, switched over to hybrid and hey presto digital tv.
Could not find many channels at first but drove into town let it auto tune and alls good Thumbs Up
I had been told by some auction site sellers that their non uk spec units were ok and would work, but its a £250-£300 error if they dont. (the line in their adverts that state please check part is compatible before buying..could spell trouble!! if you may try to return it?)
Glad I found an original Very Happy Now I can watch tv while mrs zet goes shopping ha ha
(not to slate all the good fleabay sellers out there, ive bought loads for my ffrr with no probs at all) Smile
Post #222545 12th Nov 2013 11:33pm
paul271
This is perhaps a stupid question so please feel free to stick the boot in but does this also give you digital radio?
Post #222552 13th Nov 2013 12:26am
zetjester
that's a good question, I didn't think to try the radio! I'll give it a go tomorrow and let you know Thumbs Up
Post #222553 13th Nov 2013 1:13am
paul271
Post #222555 13th Nov 2013 1:36am
B9er
Northern Ireland 2010 Range Rover Autobiography 5.0 SC V8 Java Black
When I fitted a hybrid TV tuner to my previous '06 FF it didn't provide DAB radio as the radio uses a separate tuner I believe Big Cry don't know if you can replace the radio tuner with a later DAB one though, so that be an option Question Should've been old enough to know better...doh!
Current 2010 5.0 SC Autobiography
Previous 2006 TD6 Vogue SE
Previous 1998 P38 4.6 Vogue Autobiography 50 (No 10)
Post #222560 13th Nov 2013 5:54am
the hybrid doesn't have digital radio unfortunately, the dab unit on the 2009 onwards ranges wont work on the earlier ranges..
so the only way to get dab is an aftermarket unit ... ... - .- -.
Post #222573 13th Nov 2013 8:25am
gvw
zetjester wrote:
I have just bought gvw's unit (cheers again Gary)Smile
No worries Jez - glad everything is ok Thumbs Up
The DAB is a separate module in the disco so assume it's the same in the FFRR
Post #223045 14th Nov 2013 10:49pm
ksskaret
Norway 2010 Range Rover Autobiography TDV8 Santorini Black
Has the AH42-19C063-AE MPEG-4 compatibility or is it restricted to MPEG-2? Range Rover TdV8 Autobiography MY2010
Defender 110stw Td5 MY2006
Post #229678 16th Dec 2013 10:37pm
TerryT-J
Wales 2005 Range Rover Vogue Td6 Java Black
Sorry to resurect an old post, but there are a cople of tuners on Fleabay with an AC suffix ie AH42 19C063 AC Will this do for my 2005 MY touchscreen?
Post #255099 19th Apr 2014 2:13am
