Home > Off Topic > Gutter repair
crookedm
2007 Range Rover Vogue SE TDV8 Java Black
Gutter repair
I have old style iron gutters that have decided to leak. Right now I don't want to replace them (repairs to FFRR have taken the Censored last month).
Can anyone recommend a good repair material for several leaks? Main concern is the one dripping onto a flat roof. Confused :
Post #221215 6th Nov 2013 5:42pm
TugRR
We had all ours replaced last year with new cast Shocked and used a non setting gutter mastic at each join. Hideous to work with, but very effective.
Evostick do a narrow mastic roll - I've seen it in B & Q - perhaps try that ?
I presume it's the joins between each length and not the actual gutters breaking up ?
Thumbs Up Where do you go after one of these . . . ?
Post #221222 6th Nov 2013 6:08pm
I have cast gutters as well. This summer I rubbed them all down at the front of the house and painted them. I sealed the joints with a good quality silicone sealer. The nut and bolt had rusted away so they were easy to lift apart. I completely filled the joint and pressed them together. I have perfect seals. The joints were cleaned and dust free before I applied the silicone.
Funnily, it was a leak from the guttering onto the flat roof of our porch that prompted me to do it.. Previously..
Post #221232 6th Nov 2013 6:42pm
crookedm
Thanks for replies. Yes it's the join, well on first appearances anyway.
What did you paint them with and was it a wire brush you rubbed them down with?
I will look in B&Q for the goods!
Great weather to be doing this Thumbs Up
Post #221279 6th Nov 2013 9:05pm
I used a sander.. The small triangular pad type sander. I used quite a rough grade paper and just removed the loose flakes of paint... It was quite quick to do. I used a satin type paint for wood and metal. I got it mixed up at b&q to match some newer guttering at the back of the house. There was lots of paint available on the shelf for exterior metal.
Hopefully it should last for many years to come. Previously..
Post #221301 6th Nov 2013 9:32pm
http://www.screwfix.com/p/no-nonsense-roof...10ml/67521
Have a go with that. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #221305 6th Nov 2013 9:38pm
crookedm
Great thanks all, shopping list compiled.
Glad everyone's suggested repairs not rip out and replace.
Post #221315 6th Nov 2013 10:03pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
The quickest and easiest way to repair any leaking joints is this........
http://www.screwfix.com/p/flexacryl-roof-r...-1kg/57518
Just sweep the gutter out and then paint it on...
Post #221331 6th Nov 2013 10:29pm
