![]() | Home > Off Topic > Gutter repair |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1199 ![]() ![]() |
We had all ours replaced last year with new cast |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
I have cast gutters as well. This summer I rubbed them all down at the front of the house and painted them. I sealed the joints with a good quality silicone sealer. The nut and bolt had rusted away so they were easy to lift apart. I completely filled the joint and pressed them together. I have perfect seals. The joints were cleaned and dust free before I applied the silicone.
crookedm Member Since: 23 Sep 2012 Location: Heswall Posts: 698 ![]() ![]() |
Thanks for replies. Yes it's the join, well on first appearances anyway.
I used a sander.. The small triangular pad type sander. I used quite a rough grade paper and just removed the loose flakes of paint... It was quite quick to do. I used a satin type paint for wood and metal. I got it mixed up at b&q to match some newer guttering at the back of the house. There was lots of paint available on the shelf for exterior metal.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8687 ![]() ![]() ![]() |
http://www.screwfix.com/p/no-nonsense-roof...10ml/67521
Great thanks all, shopping list compiled.
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
The quickest and easiest way to repair any leaking joints is this........
