Home > Technical (L405) > Sdv8 resonance/vibration.
Sb
England 2014 Range Rover Autobiography SDV8 Luxor
Glad to say my front anti roll bar knock seems to have been sorted.
Unfortunately, I still have a strange resonance at around 1300 rpm whilst under load from the nearside.
Just wondering how many others are having a similar issue and any definite fixes, it's going back to dealers for second time with this fault this week!
So far it's been back every week I've had it:-(.
Post #215233 8th Oct 2013 5:21pm
scott4197
United Kingdom 2018 Range Rover Vogue SDV8 Baltic Blue
I have had the resonance from day 1 too.
I think it is harmless so I have just ignored it.
There is a service bulletin on this website somewhere saying it is of no consequence:-
www.landrovertechinfo.com/
I can't find my user name right now to get the details but I suggest not to worry too much.
Post #215296 8th Oct 2013 8:17pm
Sb
Thanks everyone. Yes there is bulitin on this resonance problem. The fix is to bend the heat shield away. Simple.
All sorted now, lets look forward to trouble free motoring......
Post #215912 11th Oct 2013 4:52pm
tboner001
England 2014 Range Rover Autobiography SDV8 Fuji White
what was the fix on the NS knock ? Far to many gone...
Post #220973 5th Nov 2013 7:00pm
Sb
Active anti roll bar unit, or something like that.
Still not 100% I don't still feel something knock now and again, it maybe me.
Post #220977 5th Nov 2013 7:15pm
tboner001
agh yes had mine done , still the same as you random bumping from front end Far to many gone...
Post #221805 9th Nov 2013 9:13am
RR4ever
United Kingdom 2015 Range Rover Autobiography SDV8 Mariana Black
Knocking
The knocking is a known problem although you will not find JLR admitting to it. There is a TOPIX bulletin on it. I had it within a week on my MY14 SDV8 Autobiography. It seemed to happen more often when going over one pothole (rather than both front wheels) and it seemed to happen a split second after the "bump" if that makes sense. I was dubious going to the main dealer and trying to explain this. Luckily the experienced RR technician in the workshop went out with me and confirmed the issue. What followed was an 8 day stay in the workshop for the vehicle while he went through all of JLR bulletin on the issue (6 pages) which started off with checking the torque settings on all suspension nuts (as you would expect 100% ok) and ending up with replacement of the active anti-roll bar (they call it the ARC). I'm not an expert but it is the anti-roll bar that fits across the vehicle and has within it various dampers, compensating actuators etc. Apparently they are on the third generation of the ARC on the L405 although the technology has been on the Sport for a while (and had its problems). Whether they have it 100% sorted or not I can't say but it cured my problem. It was something to do with air in the high pressure system as the computer tries to deal with a pothole on one side. It gets out of sync and air meeting hydraulic fluid causes a knocking as the computer tries to "catch up " with the problem, hence the apparent delay in the noise. Does all this make sense to someone?
Good luck. MY15.5 SDV8 4.4 A/B FFRR Mariana/Ivory
Ten other FFRR since 2002 either traded in or taken back by JLR
Post #222418 12th Nov 2013 5:54pm
GlassMan44
United Kingdom 2014 Range Rover Autobiography SDV8 Mariana Black
I have this vibration problem at idle as soon as I increase revs ro 700 rpm it stops any ideas?
Post #464950 17th Jan 2018 10:20pm
pierre_l
Switzerland 2014 Range Rover Autobiography SDV8 Santorini Black
1300 rpm metalic noise vibration
I have the same noise - Did anyone of you actually do this? or is the dealer supposed to do it for free???
thanks in advance
p
Post #644912 6th Oct 2022 1:14pm
