Home > Technical (L405) > Sdv8 resonance/vibration. |
scott4197 Member Since: 07 Oct 2013 Location: Wolverhampton Posts: 58 |
I have had the resonance from day 1 too.
8th Oct 2013 8:17pm |
Sb Member Since: 18 Sep 2013 Location: Leeds Posts: 33 |
Thanks everyone. Yes there is bulitin on this resonance problem. The fix is to bend the heat shield away. Simple.
11th Oct 2013 4:52pm |
tboner001 Member Since: 22 Jan 2011 Location: Bucks Posts: 691 |
what was the fix on the NS knock ? Far to many gone... |
5th Nov 2013 7:00pm |
Active anti roll bar unit, or something like that.
5th Nov 2013 7:15pm |
agh yes had mine done , still the same as you random bumping from front end Far to many gone... |
9th Nov 2013 9:13am |
RR4ever Member Since: 14 Aug 2013 Location: Hertfordshire Posts: 21 |
The knocking is a known problem although you will not find JLR admitting to it. There is a TOPIX bulletin on it. I had it within a week on my MY14 SDV8 Autobiography. It seemed to happen more often when going over one pothole (rather than both front wheels) and it seemed to happen a split second after the "bump" if that makes sense. I was dubious going to the main dealer and trying to explain this. Luckily the experienced RR technician in the workshop went out with me and confirmed the issue. What followed was an 8 day stay in the workshop for the vehicle while he went through all of JLR bulletin on the issue (6 pages) which started off with checking the torque settings on all suspension nuts (as you would expect 100% ok) and ending up with replacement of the active anti-roll bar (they call it the ARC). I'm not an expert but it is the anti-roll bar that fits across the vehicle and has within it various dampers, compensating actuators etc. Apparently they are on the third generation of the ARC on the L405 although the technology has been on the Sport for a while (and had its problems). Whether they have it 100% sorted or not I can't say but it cured my problem. It was something to do with air in the high pressure system as the computer tries to deal with a pothole on one side. It gets out of sync and air meeting hydraulic fluid causes a knocking as the computer tries to "catch up " with the problem, hence the apparent delay in the noise. Does all this make sense to someone?
12th Nov 2013 5:54pm |
GlassMan44 Member Since: 21 Nov 2017 Location: London Posts: 7 |
I have this vibration problem at idle as soon as I increase revs ro 700 rpm it stops any ideas? |
17th Jan 2018 10:20pm |
pierre_l Member Since: 06 Oct 2022 Location: Geneva Posts: 6 |
I have the same noise - Did anyone of you actually do this? or is the dealer supposed to do it for free??? thanks in advance p |
6th Oct 2022 1:14pm |
