Home > Technical (L322) > Dreaded gearbox overheat! |
DeltaC Member Since: 23 Mar 2010 Location: Aberdeenshire Posts: 148 |
Very straightforward.
9th Jul 2010 6:05pm |
Nappler Member Since: 09 Jun 2010 Location: Surrey Posts: 158 |
Thanks, doesn't sound too bad, I will change the rad myself but think I will get the gearbox oil changed at a garage as I don't really know what I'm doing when it comes to gearboxes.
9th Jul 2010 6:22pm |
Condenser is in front of the radiator but the hoses go past the side of the radiator. No need to move them, the radiator comes straight up. You need to do a slight wiggle as the lower outlet comes past the fitting but its not a problem.
9th Jul 2010 11:04pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
hi, dont want to sound stupid but how do you know when your box is overheating... V8 facelift Range Rover Autobiography 22" wheels.
9th Jul 2010 11:43pm |
The box won't shift up until high revs, transmission overheat alert on the dash, after turning the car off for a few minutes and back on the car behaves as normal. Thanks again for the advice Delta, when the rad is replaced is it just a matter of letting the coolant flow through and topping up, I will make sure I have quite alot on hand. |
10th Jul 2010 12:44am |
The gearbox goes into protection mode when it gets too hot - This mode has similar characteristics as "Sport Mode", ie, it holds onto gears for longer on the way up, and shifts down quicker. If it still can't dissipate the heat, the warning message comes up.
10th Jul 2010 9:22am |
