Home > Technical (L322) > Dreaded gearbox overheat!
Nappler
2003 Range Rover Vogue 4.4 V8 Java Black
Mine has done it today after being on the motorway for a while then getting stuck in traffic.
Do I just need to change the main front radiator? And refill with coolant as I understand the bottom part which cools the gearbox gets clogged up, and mine is right on the milage this happens at-75k.
Is changing the rad on these quite straightforward?, I would rather do it myself if I can so if anyone has any tips I would be grateful.
Post #21979 9th Jul 2010 4:59pm
DeltaC
United Kingdom 2003 Range Rover Vogue 4.4 V8 Buckingham Blue
Very straightforward.
I'd also replace the hoses, belts and consider the water pump.
Remove the top hose.
Unplug the plugs to the sensor on the cowling, move the wiring out of the way.
Remove the fan (LH thread) & cowling.
Remove lower hose to the gearbox heat exchanger and lower hose with thermostat.
Remove the two plastic screws in the slam panel and ease it forward, pull the radiator assembly up and out.
Replacement is the reverse of removal.
Refil with the correct concentration of coolant.
As you've now overheated the oil and its done 75kmiles, seriously consider dropping the sump off the gearbox and giving it and the magnets a clean and renew the filter and oil.
Post #21980 9th Jul 2010 5:05pm
Nappler
Thanks, doesn't sound too bad, I will change the rad myself but think I will get the gearbox oil changed at a garage as I don't really know what I'm doing when it comes to gearboxes.
Sorry, also to add it looks like there are some A/C hoses in that area too, are they all out of the way of the rad?, I'm assuming the condenser is in the same sort of area.
Post #21983 9th Jul 2010 5:22pm
DeltaC
Condenser is in front of the radiator but the hoses go past the side of the radiator. No need to move them, the radiator comes straight up. You need to do a slight wiggle as the lower outlet comes past the fitting but its not a problem.
Honestly, with the gearbox, if you can get safe, comfortable access to the area (pit / ramp) its straightforward and there is an excellent "how to" on the www.
Post #22000 9th Jul 2010 10:04pm
daveo
hi, dont want to sound stupid but how do you know when your box is overheating... V8 facelift Range Rover Autobiography 22" wheels.
Post #22005 9th Jul 2010 10:43pm
Nappler
The box won't shift up until high revs, transmission overheat alert on the dash, after turning the car off for a few minutes and back on the car behaves as normal.
Thanks again for the advice Delta, when the rad is replaced is it just a matter of letting the coolant flow through and topping up, I will make sure I have quite alot on hand.
Post #22006 9th Jul 2010 11:44pm
DeltaC
The gearbox goes into protection mode when it gets too hot - This mode has similar characteristics as "Sport Mode", ie, it holds onto gears for longer on the way up, and shifts down quicker. If it still can't dissipate the heat, the warning message comes up.
The amount of corrosion inhibition in the system is important as there is a lot of alloy in the system (rad etc). I replaced the old coolant with a new 50/50 mix, the new concentrate being bought from Land Rover. I'd suggest that you don't just use any old antifreeze as some of the modern versions don't mix together.
Once you've put everything back together, patiently top upthe header tank until its on the line. Give the top hose a squeeze and you'll probably see bubbles coming back through the little breather pipe from the top of the radiator into the header tank. Once correctly full, start the car, check around for leaks and monitor the level in the header tank for a couple of mins, then put the cap on and take it for a short drive - Check the heater is working and then let the car cool down again (Don't remove the cap on a hot engine). ie, overnight. Then check the level again when its cool and top up if necessary.
HTH
Post #22011 10th Jul 2010 8:22am
