Home > Maintenance & Mods (L322) > Bonnet to Service / workshop setting
n1cktdv8
Ok, so I am not Geoff Capes so to ge the battery out I think there is a bonnet service setting that lifts it higher that the normal "open to check fluids" level...
Searched wiki....nothing there, any help chaps ? Is this where I put the car details and a bit about myself ?........
Post #219695 30th Oct 2013 11:36am
Nick... Thumbs Up
http://www.fullfatrr.com/forum/topic8911.h...ce+setting Si. <This is my name.
Post #219696 30th Oct 2013 11:40am
Make sure that you secure the gas struts when trying to put the bonnet back down, otherwise its too easy to scratch the paint. Otherwise its a 1 person job. There is nothing that can't be fixed with a hammer😜😜
Post #219698 30th Oct 2013 11:52am
wealy
I wouldn't risk it on my own - get someone to hold it open for you until its fully open and then if you are outside tie to back with a piece of string as the wind might catch it!
Big Cry
Post #219712 30th Oct 2013 12:59pm
n1cktdv8
Wealy that's a good call Thumbs Up Is this where I put the car details and a bit about myself ?........
Post #219714 30th Oct 2013 1:04pm
Remove strut bottom clip on one side and while supporting the weight of the bonnet remove the strut from pin, go round and do the same at the other side, lift bonnet to the service position and lock with the tabs...Simple
Post #219716 30th Oct 2013 2:07pm
To make life easier when changing the battery and after disconnecting the battery terminals, remove the red positive cable from the bolt that goes through the bulkhead (the boly for jump starting) and move the complete cable assembly to the side
Post #219717 30th Oct 2013 2:10pm
n1cktdv8
Ok, after much messing I am going to do the battery this evening....I have gone for the Bosch S5 and just collected it from local supplier....any fitting tips, it's a hell of a size !! Is this where I put the car details and a bit about myself ?........
Post #219724 30th Oct 2013 2:39pm
Googsy
Its one of lifes most enjoyable experiences fitting that battery its a very tight fit but its does go in. Straight forward but follow wiki guide to ensure the system has shut down fully. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #219728 30th Oct 2013 3:06pm
n1cktdv8
Cheers Conor.....will follow it fully, head torch at the ready ! Is this where I put the car details and a bit about myself ?........
Post #219733 30th Oct 2013 3:33pm
ebajema
I was lazy and didn't put the bonnet in service pos and still got my 100 Ah battery in. Wasn't easy but doable and I am no big muscle monster either (just a pencil pusher office worker Smile ). It was a bit fiddly but did work fine. MY 2010 5.0 SC Galway green and sand interior!!
Post #219749 30th Oct 2013 4:49pm
10 minute job
Post #219752 30th Oct 2013 4:51pm
n1cktdv8
Bonnet currently in service mode...waiting 20 min with a cuppa for the pos terminal to be ready then its a straight swap ! Is this where I put the car details and a bit about myself ?........
Post #219756 30th Oct 2013 4:57pm
Googsy
I gave up working from home as the rangy always took preference cleaning and doing bits as and when it was quiet. Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #219772 30th Oct 2013 5:27pm
n1cktdv8
Ok, so does someone fancy showing me how the Censored this Bosch S5 fits.....
I can get it in but the pos terminal wont fit Embarassed Is this where I put the car details and a bit about myself ?........
Post #219774 30th Oct 2013 5:45pm
