Home > Technical (L322) > My rear washer doesn't work
Jammer600
2009 Range Rover Vogue TDV8 Buckingham Blue
Hi
I've taken my rear wiper shroud off today to find out what's my problem, I pulled the pipe if the nosle and pushed my washer but no fluid came out at all. I tried sucking the pipe and got some fluid so I'm guessing my pumps gone, any ideas to its whereabouts please?
Post #219568 29th Oct 2013 7:30pm
there are 3 entries in the wiki re this Jammer Thumbs Up ... - .- -.
Post #219570 29th Oct 2013 7:37pm
Jammer600
Cheers Stan, I've seen those but as far as I can see there's nothing on the whereabouts of the pump? I'm getting nothing through my hose so the problem is before the problematic area others have spoke of
Post #219597 29th Oct 2013 9:21pm
isnt the pump at the front somewhere?
any thing in the workshop manual.. ... - .- -.
Post #219603 29th Oct 2013 9:46pm
Did you take the pipe off before the NRV? They are bad for blocking/failing.. Previously..
Post #219612 29th Oct 2013 10:38pm
Pumps and tank are in front of your NSF wheel, behind the front bumper... Access is found behind the splash guard Thumbs Up cannot remember weather it's the inside one (nearest the engine ) or the middle one as the outside one is for the headlights so unplug one and see if the front screen-wash disappears and voila Thumbs Up
Post #219618 29th Oct 2013 11:19pm
Jammer600
Cheers Craig I'll take a look tomo! Duno what NRV is?
Post #219620 29th Oct 2013 11:27pm
Dolphinboy
Non return valve - often gets stuck resulting in lack of flow. Thumbs Up
Post #219621 29th Oct 2013 11:29pm
Ahh ya beat me to it Thumbs Up
Post #219622 29th Oct 2013 11:31pm
Jammer600
Where would that be at the wiper end?
Post #219639 30th Oct 2013 7:02am
nrv at the wiper end.. ... - .- -.
Post #219646 30th Oct 2013 7:46am
It's the plastic bit in the pipe, just before it goes into the rear wiper assy.... Take the pipe off before the NRV and try the skoosher!! Previously..
Post #219658 30th Oct 2013 8:33am
My rear wiper wasn't working but all sorted now Click Thumbs Up Thumbs Up
Post #219663 30th Oct 2013 8:51am
TugRR
. . . Before you do any serious dismantling, check the parts mentioned above.
I had the same with mine - fixed by buying a new NRV for a few quid and clearing the nozzles with a very thin drill bit.
Easy job only blighted by the removal of the interior trim panel at the top of the tailgate . . .
Thumbs Up Where do you go after one of these . . . ?
Post #219682 30th Oct 2013 9:29am
