Home > Technical (L322) > My rear washer doesn't work |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35379 |
there are 3 entries in the wiki re this Jammer ... - .- -.
29th Oct 2013 7:37pm |
Jammer600 Member Since: 31 Mar 2013 Location: Bath Posts: 212 |
Cheers Stan, I've seen those but as far as I can see there's nothing on the whereabouts of the pump? I'm getting nothing through my hose so the problem is before the problematic area others have spoke of |
29th Oct 2013 9:21pm |
isnt the pump at the front somewhere?
29th Oct 2013 9:46pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
Did you take the pipe off before the NRV? They are bad for blocking/failing.. Previously..
29th Oct 2013 10:38pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
Pumps and tank are in front of your NSF wheel, behind the front bumper... Access is found behind the splash guard cannot remember weather it's the inside one (nearest the engine ) or the middle one as the outside one is for the headlights so unplug one and see if the front screen-wash disappears and voila |
29th Oct 2013 11:19pm |
Cheers Craig I'll take a look tomo! Duno what NRV is? |
29th Oct 2013 11:27pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3167 |
Non return valve - often gets stuck resulting in lack of flow. |
29th Oct 2013 11:29pm |
Ahh ya beat me to it |
29th Oct 2013 11:31pm |
Where would that be at the wiper end? |
30th Oct 2013 7:02am |
nrv at the wiper end.. ... - .- -.
30th Oct 2013 7:46am |
It's the plastic bit in the pipe, just before it goes into the rear wiper assy.... Take the pipe off before the NRV and try the skoosher!! Previously..
30th Oct 2013 8:33am |
My rear wiper wasn't working but all sorted now Click |
30th Oct 2013 8:51am |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1199 |
. . . Before you do any serious dismantling, check the parts mentioned above.
30th Oct 2013 9:29am |
