Home > In Car Electronics (L322) > cd changer in glove box exchange |
DTaylor Member Since: 15 May 2013 Location: Manchester Posts: 163 |
Mine is broken also. You can unplug it easy at the back, if you send it to clarion they just straight exchange it for £220-£230. When i unplugged mine it just shows the landrover logo. But supposedly if you drive for a while it should come on without it plugged in.
4th Oct 2013 9:06pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
If you unplug it you will break the "daisy chain" fibre optic and no other infotainment will work... Have you tried a battery reset? |
4th Oct 2013 9:16pm |
adigorn Member Since: 18 Mar 2010 Location: West Midlands/Birmingham Posts: 204 |
there should be no fiber optic on 2004 my cd changer you should be able to unplug it and still use the car audio |
4th Oct 2013 9:25pm |
54 reg touch screen = fibre optic |
4th Oct 2013 9:36pm |
me bad then sorry |
4th Oct 2013 9:40pm |
4th Oct 2013 9:49pm |
steve9bug Member Since: 25 Aug 2013 Location: sunderland Posts: 356 |
right a bit of insight into what happening with it then. i have removed fuses and checked them they are ok. most of the time it wont find the cd changer when i select it on the screen. now and then it will say no disc but not often. the cd cassette will not eject most times but now and again it will take it in and eject it but will not play any discs. any help as to resetting the battery would help do i need any codes for my sat nav unit if so would these be in the handbook and wallet with the service history. |
5th Oct 2013 7:26am |
Sounds exactly same as my problem. Says no disk. If you hold eject while unplugging the back and plugging back in. Sometimes it ejects. But looks like fleabay, clarion or fm transmitter.
5th Oct 2013 7:47am |
Well just thought i would try and look at it, removed the CD Changer and dropped it off at the audio shop he says it needs a service and says it will be about and hr so lets see if it works when i get it back.
28th Oct 2013 12:38pm |
Well went to collect the changer no charge oh two small parts were stuck inside he said a small steel pin and a plastic part with a hole in that the pin went into. He said he could not see where it was from strange when i took it out and shook it there were no bits rattling about in the unit.
28th Oct 2013 3:54pm |
