Home > Technical (L322) > Can you stop the steering wheel from retracting?
Mine's started working again and every time I turn the car off it retracts. This is: -
a) Irritating.
b) I know it will break in the wrong position sometime.
Can I stop it - e.g. is there a fuse I can pull or a wire? I'd rather it just stayed in one position (the correct one) than it breaks in the wrong one.
Thanks - couldn't find anything on this?
Post #218803 26th Oct 2013 7:39am
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
IID Tool lets you deactivate it - I did it as soon as I got my IID as like you, I was pretty sure that it would break at some point Rolling with laughter Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #218806 26th Oct 2013 7:44am
supershuttle
I turned my "easy entry/exit" feature off with the IDTool. The adjuster stalk still works so the wheel can be fine tuned after placing ones behind in the drivers seat and the memory positions still work. Geoff
Post #218807 26th Oct 2013 7:46am
David, if it has not worked until now, first try a battery reset... If that does not work just unplug the motor Thumbs Up Very simple Thumbs Up
When i next see you i'll turn the auto feature off...
Post #218808 26th Oct 2013 7:47am
I have no ID tool. Sad
Is there another temporary way until my next shop visit?
Post #218809 26th Oct 2013 7:48am
Hi Craig - it started working again when I had the tyres changed and the tracking done. Bizzare that it just decided to start again.
Post #218810 26th Oct 2013 7:49am
supershuttle
No IIDTool then do what Craig says.
Mine didn't misbehave all of the time but it did Censored me off - now it doesn't Thumbs Up Geoff
Post #218819 26th Oct 2013 8:17am
oldcro
United Kingdom 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
Have you tried turning the steering column adjuster? Push, pull ,up and down moves the column and a twist should switch the automatic retract on and off.
Maybe! Whistle
Post #218859 26th Oct 2013 1:06pm
What about puting it all the way in then saving to memory that position? Or would that be too far away for you to drive? Previously..
Post #218861 26th Oct 2013 1:15pm
I want it all the way out!
Post #218862 26th Oct 2013 1:19pm
wealy
On the 2010 My you can switch it on of off on the dash
Post #218874 26th Oct 2013 2:29pm
steve9bug
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Just seen this post never though about it but mine done work now but I have had the auto door locking turned off on moving has this any link to it or anything else I have turned off it still works on the stalk
Post #218907 26th Oct 2013 4:24pm
roger 47
United Kingdom 2017 Range Rover Autobiography SDV8 Fuji White
Fuse 20 and 23 in the passenger compartment fuse box. '88 RR Classic, '90 Classic, '93 Classic, '02 Discovery TD5, '55 Discovery 3, '01 P38 4.6, '06 L322 Vogue TD6, 2012 L322 Vogue TDV8, 2017 L405 Autobiography
Wife. '01 Freelander, '07 Freelander 2.
Post #219048 27th Oct 2013 12:24pm
steve9bug
looked at them today both look ok
Rolling Eyes
Post #219050 27th Oct 2013 12:27pm
roger 47
What I should have said is to set the steering wheel where you want it and then take out the fuses, it would stay in that position.
My steering wheel, motors down sometimes when I put the key in the ignition. I can then return it with the normal adjustment lever. I wondered if it was the key fob memory had glitches that was affecting the seat and steering wheel memory module settings.
I did replace the batteries but that didn't do anything. It only does at on rare occasions at present. '88 RR Classic, '90 Classic, '93 Classic, '02 Discovery TD5, '55 Discovery 3, '01 P38 4.6, '06 L322 Vogue TD6, 2012 L322 Vogue TDV8, 2017 L405 Autobiography
Post #219056 27th Oct 2013 12:48pm
