![]() | Home > Maintenance & Mods (L322) > brake 'grind' |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35485 ![]() ![]() |
i have an annoying brake grind noise when i come to the final seconds of a slow stop..its very not loud but because i know its there ,its bugging me..
Stan, check ya don't have non OE pads fitted pal... OE all the way with your Brembo's IMHO...
Sounds like your wallet need some lubrication |
i'm pretty sure they should be OE pads as the range has always been serviced by a main dealer but unless i have a physical look i cant confirm that.. ... - .- -.
me spend money John? |
Have come across plenty of non gen pads doing this... Many with FMDSH |
interesting that Craig |
IMHO (I've only seen them used on Disco's) they are rubbish on such heavy cars... |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
OE for me every time.......... |
Just came back from lunch and sat in traffic for a while and it started again. Disappears as soon as you start driving "normally" and braking normally. It is only on the very slow braking where it makes the grinding like noise. Again all brake parts (discs, pads, calipers) are OEM. MY 2010 5.0 SC Galway green and sand interior!!
strangely today whilst taking the wife to hospital and back it didnt seem to make this noise , mind you its been dry and windy so did that dry out the brakes? ... - .- -.
greasemonkey1 Member Since: 22 Sep 2013 Location: london Posts: 157 ![]() ![]() ![]() |
well said .. ![]() |
paul271 Member Since: 19 Oct 2013 Location: Aberdeen Posts: 502 ![]() ![]() ![]() |
I get a bit of squeaking in traffic now and then but I had hat put that down to the back pads and discs needing done as they're on there last legs.
@Steve, i've had a google and it seems these yellow,green and red pads are pants on heavy motors like 4x4's so its going to be a well known make i replace mine with but which 'well known' make is better..
