Home > Maintenance & Mods (L322) > Lower Tail gate wont close
Stormin
2003 Range Rover HSE Td6 Epsom Green
Up till Sunday my lower tail gate has been closing fine, yet on Sunday it failed to close shut, I have found a cure by lifting the plastic flap, just above the latch.
My question is why has it just stopped working, is there some thing ive missed
Ive tried to attach a picture of a similar latch
Its the plastic bit to the right of the picture Three things in a blokes life his dog,his car and a Cornish pasty,nothing else matters.
2010 Range Rover Vogue SE Santorini Black, Arabica Aniline seats
Previous cars
1973 Mini 1000
1971 Hillman Avenger
1975 Chrysler Sunbeam
1981 Ford Cortina
1985 Volvo 340
1989 VW Golf
1989 Volvo 240
1991 Volvo 240
1991 Jaguar Soveriegn
1996 BMW 730
2003 Honda CRV
1999 Jaguar Soveriegn
2003 Range Rover HSE Epson Green with Sand trim.
Post #218081 22nd Oct 2013 2:01pm
paul271
Scotland 2002 Range Rover Vogue Td6 Epsom Green
Sounds like a problem with the actuator that runs the latch. The plastic tab is like a manual override.
My right latch packed up so i ordered a latch and actuator off ebay for £30. Takes about 10mins to fit.
Post #218105 22nd Oct 2013 4:17pm
TimP
England 2005 Range Rover Vogue Td6 Java Black
Could just be that the latch is "gunged up".
Take off latch - just a couple of screws/bolts - then lock and open (with key fob or dash switch) to check if actuator is operating.
If it is, then clean up latch using WD40 and light oil (3 in I) and manually open and close latch (including most importantly the plastic bit )whilst cleaning until action becomes free and easy.
Screw latch back onto actuator and hopefully job's done.
Happened to me last year - and I was very pleased with a "free fix" for the Rangie.!!
Hope this helps.
Tim
Post #218112 22nd Oct 2013 4:48pm
Stormin
Thanks TimP and Paul271, had a look on eBay and have seen what you mean, as I need to take it out to check the numbers I'll have a go at cleaning as you've suggested first and if that fails, I can order another
Thanks again
Steve Three things in a blokes life his dog,his car and a Cornish pasty,nothing else matters.
Previous cars
1973 Mini 1000
1981 Ford Cortina
1985 Volvo 340
1989 VW Golf
1989 Volvo 240
1991 Volvo 240
1996 BMW 730
2003 Honda CRV
Post #218114 22nd Oct 2013 4:53pm
paul271
Good shout from Tim about trying a good clean first. Mine was knackered but free's the best price!!
Post #218115 22nd Oct 2013 4:55pm
Stormin
Paul there's one on eBay for £25, buts its for a 2006, so i'll have to take it out to check to see if its the same number.
Mine will most likely be knackered too. Three things in a blokes life his dog,his car and a Cornish pasty,nothing else matters.
Previous cars
1973 Mini 1000
1981 Ford Cortina
1985 Volvo 340
1989 VW Golf
1989 Volvo 240
1991 Volvo 240
1996 BMW 730
2003 Honda CRV
Post #218125 22nd Oct 2013 7:00pm
paul271
£31.45 for a left or right on eBay and that includes the actuator.
I think they're the same in the later models definitely worth double checking though.
Post #218127 22nd Oct 2013 7:04pm
Stormin
Again other forum members have saved me some money, took both latches off, cleaned and re oiled, Both working fine.
Just be careful when removing the latch, I found that due to the crud, when I pulled the latch away from the body the top spindle in the actuator fell out. Its only a push fit back in and retightening of a spring. But involves removing the door top trim and door card.
Thanks again Paul271 and TimP Three things in a blokes life his dog,his car and a Cornish pasty,nothing else matters.
Previous cars
1973 Mini 1000
1981 Ford Cortina
1985 Volvo 340
1989 VW Golf
1989 Volvo 240
1991 Volvo 240
1996 BMW 730
2003 Honda CRV
Post #218246 23rd Oct 2013 10:00am
paul271
Glad to hear it was an easy fix mate.
Post #218249 23rd Oct 2013 10:08am
