Home > In Car Electronics (L322) > Headlamp
Swiftman
Scotland 2006 Range Rover Vogue SE Td6 Zermatt Silver
Headlamp
When I switch on headlamps they adjust to correct height , tonight only o/s one came up n/s one is to low help needed what could be wrong Bow down Bow down
Post #217229 17th Oct 2013 7:56pm
probably a glitch...try turning the ignition on/off a few times and/or check the connections on the back of the headlight.. ... - .- -.
Post #217235 17th Oct 2013 8:08pm
mike & the mechanics
United Kingdom 2007 Range Rover Vogue SE TDV8 Galway Green
Sounds like it could be motor failure but you could check fuse no 48 which is for the left hand light behind the glove box the right hand one is fuse 54. Hope this helps. Should add it depends if the fuse box locations are the same in the later TDV8s if not check your handbook Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!!
Post #217238 17th Oct 2013 8:08pm
Swiftman
Thank you
Headlamp cured itself range rover gremlins strike again Thanks for the advice Thumbs Up
Post #218132 22nd Oct 2013 7:55pm
