Home > Technical (L322) > Alternator removal TDV8 |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6366 |
Did you have to remove the grille and front bumper to make access easier?
17th Oct 2013 5:46pm |
mike & the mechanics Member Since: 08 Sep 2013 Location: Lincolnshire Posts: 178 |
No with the rads still in place it would be a bit silly to take them off. Space is tight but the awkward part is getting the Alternator out past the turbo pipe work. Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!! |
17th Oct 2013 5:52pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
17th Oct 2013 5:57pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Present :2008 TDV8 HSE
17th Oct 2013 6:16pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8504 |
Good to know
17th Oct 2013 6:22pm |
Only coolant as obviously all the rad pipework gets in the way but not the header tank that I have read people remove, I really could not see why I think the difference is in the belts & pulleys I was offered a 6pk or 8pk Alternator /belts. However the 6pk belt is a lot shorter. until I ordered the Alternator I did not realise there was a choice.Luckily I could still read my belt numbers & it is Ok but at £18.50 I think for a new belt seemed mad not to change it as well Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!! |
17th Oct 2013 6:28pm |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
Great write up Mike, gives me the confidence to swap out my alternator. 56 TDV8 Vogue SE
17th Oct 2013 8:08pm |
I have realised that nothing in the engine bay of mine is simple to do or get at but with small hands, a large hammer & plenty of expletives any thing can be achieved Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!! |
17th Oct 2013 8:22pm |
Put it all back together this morning hardest part was putting the nut on top of the main battery feed on top of the Alternator. Dropped it twice & wasted half an hour with a boroscope & magnet trying to retrieve it. Now charging at 14.6 v & am hoping the battery is ok after being totally flattened, so I may invest in a new one before the frosts start. I would estimate with tea brakes & the odd cigar about 6hrs in total Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!! |
18th Oct 2013 5:19pm |
martylennox Member Since: 05 Aug 2013 Location: Co Antrim Posts: 9 |
any ideas on how to get at the alternator wires for disconnection,? im in the middle of the dreadded tdv8 alternator change.
7th Nov 2013 7:48pm |
Marty good to hear that now I know who to contact if mine goes being a fellow Antrim man Present :2008 TDV8 HSE
7th Nov 2013 7:54pm |
small hands required! |
7th Nov 2013 8:01pm |
Disconnect the feed from the starter so you can pull it forwards Hope that helps Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!! |
7th Nov 2013 8:12pm |
Should have added it will come past the turbo pipework just requires a bit of wriggling Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!! |
7th Nov 2013 8:15pm |
