![]() | Home > Technical (L322) > Overheating? Coolant Loss & PTFE (2 recent Rads fitted) |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
Hmm interesting....
MD very helpfully contacted me twice yesterday to offer advice and offered to deal if I take the car in but it's a fair way for something I'd like to 'learn' how to sort myself and which might just be a couple of days worth of topping up/ minor adjustment so I said I'll monitor for a day or so and take it in if it doesn't settle.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35485 ![]() ![]() |
as you know ptfe tape is used on central heating systems and water/pipe temperatures can go up to around 80c so i reckon yours will be ok. ... - .- -.
Yes, cheers Stan, have also since spoken with brother in law (plumber) who says no issues using PTFE tape on this.
Ptfe should be fine.
Having experienced continuing weeps from the bleed screw and noting that the screw's closed position would alter dependant on whether the expansion tank was hot or cold, yesterday morning, when the engine was cold, I carefully wrapped a small amount of white plumber's PTFE tape around the thread of the plastic bleed screw. I then tightened (or closed) the screw taking care not to over tighten it so as not to damage the bleed screw head or the actual screw hole on the expansion tank.
I will have a look at mine and see if there is an o ring on it to see if yours is missing |
Yes. Mine has an o ring squashed at the top of the screw.
Thanks very much. PM sent |
A couple of assorted sizes are on their way. There is nothing that can't be fixed with a hammer😜😜
