Home > Technical (L322) > Airbag warning light
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
The airbag warning light occasionally lights up. Sometimes it will come on during a journey, if I stop for a short time it is usually off when I restart. Most of the time the light is not on but now and then it comes on. The light on my old Discovery was on permanently for 3 years so I am not overly concerned by this. But I am wondering if this is something I should really worry about. There are quite a few bags in my car, I don't think any are in danger of going off on their own! But maybe I am being too cavalier about this Shocked
Any thoughts? No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #75565 10th Aug 2011 9:25pm
i think when the light comes on the airbag system is disabled. so not the best in a crash. I'm not sure if ALL are disabled or just the one causing the fault. Confused [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #75568 10th Aug 2011 9:29pm
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
I believe a lit airbag warning lamp is about to be an MOT failure - if it's not already.
The fact that yours is intermittent is interesting, as I had thought that any transient airbag fault would disable the system until the dealer re-enables it. Is there anyone local who can pull the fault code for you to to help diagnose the actual problem, if not it may be time for a trip to the dealers.
Gone - Range Rover Supercharged 2006
Post #75583 10th Aug 2011 10:42pm
It will be from next year Big Cry
Post #75584 10th Aug 2011 10:44pm
mine did the same , intermittent on/off...found out it was the passenger side occupancy sensor under the seat cushion...the wife jiggled her bum on the seat and the light flickered on and off...
Post #75627 11th Aug 2011 9:09am
Mikeyjd
Come to think of it I don't recall it ever doing it when I was driving on my own, but I may be wrong. Do you remember how muchit cost to diagnose and get repaired? No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Post #75636 11th Aug 2011 10:27am
L322RR
Germany 2004 Range Rover HSE Td6 Zambezi Silver
Hi,
I am getting the same fault, with airbag light coming on and off. Plugged in my GAP tool, getting the "seat occupancy sensor" error. GAP tool erases the error, but it's just coming back.
Does anyone know the ref of the faulty sensor, and how to change it. Just can't find this on the internet, I did find on ebay a bypass for the sensor but for BMW, I don't know if this would be useful.
Thanks,
Post #216060 12th Oct 2013 2:44pm
Pfazz
2019 Range Rover Autobiography SDV8 Loire Blue
Mine had this fault last year, dealer sorted it he said it was a faulty sensor in the boot but why there I've no idea. Been ok since though. Agueroooooooooo. 93-20
I swear you will never see anything like this ever again....watch it..drink it in.
Post #216065 12th Oct 2013 3:45pm
L322RR
Ok, so after a deep search, found out that the ID of the seat sensor is HGI000010 , this is a BMW part 65778367242-05.
Seems like there is a cheap bypass possible solution for 20€, but for the BMW, should work for L322 too I believe?
Post #216204 13th Oct 2013 8:39am
for the sake of around £100 wouldnt it be better to have a working airbag and replace the seat sensor... ... - .- -.
Post #216234 13th Oct 2013 11:08am
L322RR
I agree with you, but the bypass doesn't prevent the airbag from working, just tells the sensor that someone is sitting there all the time. Anyway, if the BMW part 65778367242 (X5 and Z3 part) works on the range rover, you can find some on ebay for less then 25€
Post #216239 13th Oct 2013 11:17am
understood, i thought the workround was the other way round and that there was no one sitting there.. ... - .- -.
Post #216241 13th Oct 2013 11:20am
