Home > Technical (L322) > TDV8 Head gasket failure / warranty |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1199 |
I think some of the above conversation is of no assistance to Steve who is in a terrible predicament.
9th Oct 2013 12:45pm |
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 |
Very good points TugRR. |
9th Oct 2013 12:49pm |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1665 |
Please keep this on topic chaps.
10th Oct 2013 3:57pm |
Jim_m_kidd Member Since: 03 Oct 2012 Location: Yorkshire Posts: 69 |
SOGA - quoted here - Fault wise - it was my understanding that if the failure was within the first 6 months of ownership the fault would be assumed to be there and the supplier would have to prove it wasn't - after six months the burden is reversed with the owner having to prove the fault was already there |
11th Oct 2013 12:31pm |
Jim. I had a brief look at the SOGA checklist for second hand car dealers, and indeed you would appear to be correct if I am understanding this correctly.
11th Oct 2013 1:57pm |
mike & the mechanics Member Since: 08 Sep 2013 Location: Lincolnshire Posts: 178 |
I think the problem you may have here though is the engineer stating that unfortunately the total failure of the engine was caused by the customer driving the vehicle after the gasket failed until the engine was effectively damaged beyond economic repair. However if you read the owners handbook all data ie speed,temp & all sensors record & are stored in the vehicles ECU. this information can be retrieved by the police with a valid court order or with your permission by landrover. in fact the first ever death by dangerous driving was successful using this info against a RR driver. Big brother is in your car & that info retrieved would prove who was right. for instance if the temp/low coolant level etc were present many miles earlier it would be difficult to argue, but if they only activated a short time before stopping then your case against the warranty company is secured. Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!! |
11th Oct 2013 9:25pm |
having read my statement above I would like to clarify the first ever prosecution based on on-board stored data was on a RR not the first ever prosecution for death by dangerouse driving Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!! |
11th Oct 2013 9:27pm |
Interesting to know that while we can use the on-board stored data for our own benefit, it can also be just as easily used against us. Scary stuff!!
12th Oct 2013 12:53am |
Hi XJR, just wondering if there is any update with your car? |
21st Oct 2013 9:25am |
TDV8's are a common failure in the SSRR im afraid and has been noted a few times that there are shortages of the engines from LR to replace ones blown in warranty and as someone who has been there and seen a new engine blow it is quite concerning but i stay adamant that the FF installation is more solid longterm than the SSRR due to space around the engine for passive cooling during sitting in traffic and possibly due to the driving each vehicle attracts being different. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
21st Oct 2013 4:21pm |
^ Nearly all RRS I believe KP not heard of many L322. |
21st Oct 2013 4:33pm |
I've seen/heard of only 2 failures of a TDV8 3.6 in an RR.
21st Oct 2013 5:57pm |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
What has happend to xjr Steve ? |
22nd Oct 2013 9:50pm |
xjr264 Member Since: 08 Oct 2013 Location: Bristol Posts: 5 |
Hi guys,
3rd Nov 2013 5:51pm |
