Home > Technical (L322) > TDV8 Head gasket failure / warranty |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
I had this happen in Africa. When you lose your coolant the temp gauge is effectively measuring the air temperature - not a great solution. However the check coolant warning should trigger first (if you are lucky). Running a V8 at 2000rpm with no coolant will not end well....
4th Nov 2013 3:15pm |
Jim_m_kidd Member Since: 03 Oct 2012 Location: Yorkshire Posts: 69 |
If you can get it fixed then do that. Then small claims for damages, same timeframe as rejection but less inconvenient /risk |
21st Nov 2013 9:17pm |
hmm just reread that and didn't answer your question regarding the £3k storage. H'mmm not sure on that... |
21st Nov 2013 9:19pm |
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 |
XJR, glad to hear that the independent engineer report found you had no blame in the engine failure.
21st Nov 2013 9:50pm |
mike & the mechanics Member Since: 08 Sep 2013 Location: Lincolnshire Posts: 178 |
You could possibly negotiate repair of your RR with the garage in question & ask them in return to wave storage then claim against warranty/dealer for cost of repair. To me that would be easier & far less stressful. maybe even offer to supply a good used unit/new/reconditioned. Any business would rather come to a conclusion that everyone walks away happy than risk of court action etc. Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!! |
21st Nov 2013 10:59pm |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
3 grand storage?????
21st Nov 2013 11:00pm |
RR8701 Member Since: 11 Aug 2011 Location: East Ayrshire Posts: 380 |
Hi XJR,
22nd Nov 2013 8:07pm |
pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218 |
@xjr264:
23rd Nov 2013 7:43am |
