![]() | Home > Off Topic > Garage floor paint/resin/covering. |
The best thing you can do is leave the floor raw for 6 month to allow it to cure properly before covering it. I looked into epoxy but I found that it does eventually wear out and start lifting, especially with hot tyres sitting on it. There are different plastic tiles, some have a void underneath and would be useless for use with a trolley jack, others are able to be used with trolley jacks.
Havank Member Since: 05 Apr 2007 Location: Woking - Surrey Posts: 193 ![]() ![]() ![]() |
If you are going to paint, definately let it cure for about 5 months, otherwize the paint will lift, or just doesn't cure
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
47p2.....
Half the size of my floor area Contra |
That looks more like it. Is it straightforward grinding the surface? I take it you just hired the kit? Previously..
Yes easy to grind but a messy job |
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 ![]() ![]() ![]() |
Let it cure as above
Thanks... A primer then epoxy sounds like it may last a while. Previously..
I have grey epoxy here I could sell to you |
Sell? As in money?? |
That sounds the mutts... 2 year shelf life tho? Is it just the 5L you have? Previously..
Lovely garage 47 Any more pics |
Got a few Contra, I over ordered for the small garage |
