Home > Off Topic > Garage floor paint/resin/covering.
I have just poured a concrete slab for my new garage. The garage will be finished by the end of October and I want to have the floor ready before the car goes in.
Can anyone recommend a good quality paint or epoxy that will not lift with car tyres rolling on it?
Using the search, I see some of you have put a plastic type tile down. Can you use a trolley jack on those?
Cheers.. Previously..
Post #215381 9th Oct 2013 9:17am
The best thing you can do is leave the floor raw for 6 month to allow it to cure properly before covering it. I looked into epoxy but I found that it does eventually wear out and start lifting, especially with hot tyres sitting on it. There are different plastic tiles, some have a void underneath and would be useless for use with a trolley jack, others are able to be used with trolley jacks.
I bought my tiles from Eco Tiles (discounts available when you speak direct to them).
The only down side of these tiles is when the sun shines directly on them they expand and buckle, once they cool down they go back to lying flat, the way round this problem is to glue them down but I didn't want to go down that route so just keep the garage door closed when the sun shines inside
Post #215385 9th Oct 2013 9:28am
Havank
United Kingdom 2003 Range Rover Vogue Td6 Java Black
If you are going to paint, definately let it cure for about 5 months, otherwize the paint will lift, or just doesn't cure
as there is so much water in the concrete
Post #215388 9th Oct 2013 9:45am
47p2.....
For my 36 m2 double garage floor....
Sub-Total: £1,062.00
UK VAT Zone (Weight: 324.00kg): £49.99
VAT (20%): £222.40
Total: £1,334.39
Shocked Previously..
Post #215390 9th Oct 2013 9:49am
Half the size of my floor area Contra Big Cry
If you go down the paint/epoxy route I would recommend grinding the top off the floor, this removes all the soft powdery top layer and gives a much harder durable surface.
Post #215395 9th Oct 2013 10:05am
That looks more like it. Is it straightforward grinding the surface? I take it you just hired the kit? Previously..
Post #215397 9th Oct 2013 10:27am
Yes easy to grind but a messy job
Post #215398 9th Oct 2013 10:29am
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Let it cure as above
then heavy duty Forklift proof epoxy but use a primer we run trucks on it at a chemical factory with no problem.
Thumbs Up Mine was a blue one! Smile
Post #215399 9th Oct 2013 10:36am
Thanks... A primer then epoxy sounds like it may last a while. Previously..
Post #215405 9th Oct 2013 10:59am
I have grey epoxy here I could sell to you Thumbs Up
Post #215407 9th Oct 2013 11:14am
Sell? As in money?? Shocked .. Laughing
Grey is the colour I want actually.... Is it 2 part? I would need around 5L per coat I think.... Previously..
Post #215410 9th Oct 2013 11:30am
This
Data Sheet here
Post #215421 9th Oct 2013 12:14pm
That sounds the mutts... 2 year shelf life tho? Is it just the 5L you have? Previously..
Post #215428 9th Oct 2013 12:38pm
Googsy
Lovely garage 47 Any more pics Whistle Whistle Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #215458 9th Oct 2013 2:39pm
Got a few Contra, I over ordered for the small garage Big Cry
Post #215460 9th Oct 2013 2:45pm
