![]() | Home > In Car Electronics (L322) > SC MY06 - Some questions on the in-car electronics |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 ![]() ![]() ![]() |
Hi All, |
Many thanks for the reply, much appreciated.
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1521 ![]() ![]() |
Good luck, I hope it's an easy fix! |
Just a follow up to the above:-
Point 2) Today I have had the rear headrest screens /monitors out and swapped them (good advice Stan |
E4 GUY Member Since: 07 Jan 2013 Location: London Posts: 513 ![]() ![]() ![]() |
There is a remote. Seen them on eBay, £115 ! Mine is a bit flaky, so I tend to set film to play from front touch screen before driving off. Disadvantage is that once you've let handbrake off you can't fast forward etc
Thanks Guy, much appreciated. So in theory you could pull up at the traffic lights and use your remote on the FF next to you?!
Jpickie Member Since: 02 Nov 2011 Location: Oxfordshire Posts: 44 ![]() ![]() ![]() |
The av input panel is wired directly to the RSE module in the boot, from memory it is the blue cable. The rear screens have a number of connections before the RSE module. I had a dodgy connection on the left side under the seat next to the body control module but it did not give the same problem as you describe however cleaning it and reseating it cured the problem. There is another connection within the seat backs themselves which is a bit more time consuming to access. Both the RSE remote and the headphones work on infrared and interchangeable between vehicles, no pairing necessary, I would keep an eye out on eBay as they do regually appear on there or speak to Dan as I don't think they are that 'expensive' new. The A , B button selects the audio source from either the left or right screen. As others has said the venture cam batteries are replaceable as I have done, there is a good write up on this recently I think it was put in the WIKI. You can download all the user guides including the RSE one from the LR TOPIX Site for free. Good luck its worth having it working correctly if it's already there , keeps my kids quiet at least sometimes! MY2007 S/C - Stornoway / Jet |
You have a PM sir |
