Home > In Car Electronics (L322) > SC MY06 - Some questions on the in-car electronics |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 |
Hi All,
6th Oct 2013 8:39pm |
Many thanks for the reply, much appreciated.
7th Oct 2013 9:49am |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1511 |
Good luck, I hope it's an easy fix!
7th Oct 2013 11:33am |
Just a follow up to the above:-
13th Oct 2013 10:57am |
Point 2) Today I have had the rear headrest screens /monitors out and swapped them (good advice Stan ) and the screens are fine when swapped so it's the feed from the RSE module that is faulty. I will look in the week. Wouldn't it be nice if it was just a loose connection?! I suspect it won't be though........ 2006 4.2 SC
13th Oct 2013 6:45pm |
E4 GUY Member Since: 07 Jan 2013 Location: London Posts: 513 |
There is a remote. Seen them on eBay, £115 ! Mine is a bit flaky, so I tend to set film to play from front touch screen before driving off. Disadvantage is that once you've let handbrake off you can't fast forward etc
13th Oct 2013 7:28pm |
Thanks Guy, much appreciated. So in theory you could pull up at the traffic lights and use your remote on the FF next to you?!
14th Oct 2013 7:48pm |
Jpickie Member Since: 02 Nov 2011 Location: Oxfordshire Posts: 44 |
The av input panel is wired directly to the RSE module in the boot, from memory it is the blue cable. The rear screens have a number of connections before the RSE module. I had a dodgy connection on the left side under the seat next to the body control module but it did not give the same problem as you describe however cleaning it and reseating it cured the problem. There is another connection within the seat backs themselves which is a bit more time consuming to access. Both the RSE remote and the headphones work on infrared and interchangeable between vehicles, no pairing necessary, I would keep an eye out on eBay as they do regually appear on there or speak to Dan as I don't think they are that 'expensive' new. The A , B button selects the audio source from either the left or right screen. As others has said the venture cam batteries are replaceable as I have done, there is a good write up on this recently I think it was put in the WIKI. You can download all the user guides including the RSE one from the LR TOPIX Site for free. Good luck its worth having it working correctly if it's already there , keeps my kids quiet at least sometimes! MY2007 S/C - Stornoway / Jet |
15th Oct 2013 7:58am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16281 |
You have a PM sir |
15th Oct 2013 8:12am |
