![]() | Home > Technical (L322) > Electric seats and steering control fault |
I'd check the connector to the ECU under the drivers seat first. |
samp5679 Member Since: 25 Sep 2013 Location: houghton le spring , north east Posts: 26 ![]() ![]() |
and now the radio has stopped working great for owning car 1 week |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35489 ![]() ![]() |
is the battery ok? ... - .- -.
battery is pretty new,, it happens after driving for a while like something is over heating, now stereo/radio has turned off |
i think the radio is something different, on the driver seat is the electric switches loose, the multi plug on the switch pack will cause both them probles if loose there or under the seat as stated. V8 facelift Range Rover Autobiography 22" wheels.
I have had a fiddle with connector do you mean under the seat or on the side ????
try the plug on the side of the seat behind te switch valance,
nothing works both seats and steering adjust then tomorrow it might work for a while then off again , radio cd has gone off also |
seat and steering adjust was the wiring to the back part of seat for lumbar due to being crushed and split , it actually caught fire bellowing smoke out so careful if this happens to you, all fixed now , coolant light fixed it was sensor £9,00 for that just oil leak and bodywork imperfections then happy days ,,,, for a while |
